Frigidaire Dishwasher OrbitClean Spray Arm Issue
niclonnic
May 31, 2015
63
Bonney Lake, WA
My current dishwasher, a Frigidaire Gallery model FGID2466QF4A, came with the house and is 8-9 years old. Despite having a plastic interior, it cleans dishes well for the most part. However, there is a persistent problem that baffled me for the longest time.
A lot of dishes in the bottom rack do not emerge fully clean. This includes bowls, particularly those with soup and stubborn food residue, overly greasy pots, pans and Tupperware, as well as forks with food stuck in between the tines. Said dishes would still have food particles and/or grease leftover when I unloaded the dishwasher. However, plates and most silverware, along with every dish in the top rack, come out fully clean.
I've played around with different settings, such as adjusting the water pressure from "surge" to "scour," increasing the temperature to "hi-temp" and enabling the sanitize rinse option. However, these options only make a slight difference at best. I even upgraded the detergent from the standard Finish Powerball tabs to the Quantum type, but that didn't help matters, either. After a cycle, detergent residue often appears on the inside of the compartment door.
Before figuring out this issue, I would have to rewash the affected items by hand after unloading them. I then developed a regime of pre-rinsing and scrubbing these items before loading them into the appliance. However, in my mind, the whole point of a dishwasher is to reduce the labor spent on hand-washing dishes.
So, the other day, I did some research into these dishwashers and stumbled upon a YouTube video explaining the problem in detail. As it turns out, the so-called "OrbitClean" spray arm, which has a spinning blue end that allegedly covers a larger area for more thorough dishwashing, develops an issue where it becomes unbalanced right on the heavier end. This imbalance results in the arm turning very slowly or not at all, most likely due to insufficient water pressure. Although the arm spins freely when I turn it by hand, it tends to remain in one place during a cycle. No wonder the dishes in the bottom rack are not getting a proper cleaning!
In the video, the presenter remedied the issue by replacing the OrbitClean spray arm with a more conventional one (a genuine Frigidaire part) purchased from Amazon. Luckily, the arm is very straightforward to replace, as it's held in by a couple of plastic tabs.
After giving it some thought, I went ahead and ordered that traditional spray arm. It'll take a couple weeks to get here, though. I'll provide an update once it arrives.
This is just a notice to anyone who is having similar issues with their Frigidaire DW featuring the OrbitClean spray arm. I have included the Amazon link to the replacement arm.
Here's the repair video:
https://a.co/d/eBKjQ91
Silly Frigidaire orbit, clean wash arm
I guess these arms work for a while, but we've been replacing them with conventional arms for years now and I think you'll be pleased with the results.
We see a lot of the orbit, arms that fall apart and end up on the heating element melted. I carry in my truck the regular arm and just replace it have it ever had a complaint.
John
I have this dishwasher in my college home currently, minus the orbit arm. You'll find satisfactory cleaning in both racks with the replacement arm I am sure.
The EU version of these DWs with that spray arm (and it's similar derivatives) are known to not perform that great.
You should probably check through out the cycle. Even this DW arm should move once around every 15-30sec.
It the DW alternates spray arms, it's really easy to tell if a spray arm is rotating at all just by the sound.
But going to a different spray arm shouldn't hurt performance and is an easy and cheap remedy.
wow
i'm tired of dishwasher manufacturers "inventing" new things without thoroughly testing their longevity. top of the line Electrolux models in my country also uses the exact same system, glad i didn't get them.
but my new Bosch dishwasher also have a brand new system called PowerControl which has a weird motorized spray arm on the bottom that spins with a combination of both by a motor & water pressure. hoping it doesn't lead to similar failures in future...
I remember our 1969.....
......Frigidaire Imperial dishwasher (pushbutton cycle selection and cycle indicator lights) having a metal "orbit arm". It looked like a smaller version of the main wash arm.
I guess that is some kind of Frigidaire "feature" they have kept (or resurrected).
Frigidaire new wash arms
I am so sick and tired of Frigidaire. I had a dishwasher from them that lasted a year. A YEAR!!!! And I wouldn't trust that so-called orbit clean wash arm. Thank God I have my Kenmore built Bosch which reminds me of the Whirlpool power clean with the powerful wash system, plus a concealed heating element.
The Orbital Spray looks pretty convincingly WCi-ish enough that I wonder why Frigidaire/GM didn't come up with it sooner...
The idea that it doesn't work as well or last as long as promised, seems to be that type of trademark, too...
-- Dave
GELaundry4ever
No, I have not tried the Finish Ultimate tabs. But I do use Jet-Dry as my rinse aid. I doubt that stepping up to the Ultimate detergent would make a big difference.
I agree, Frigidaire is hit or miss. Nearly all the appliances in my house are by that brand. I say "nearly" because I had a few Frigidaire appliances that had to be replaced last year due to leaking issues, namely the refrigerator and washer/dryer. I have posted about these new appliances before, so I won't go into detail about them here.
At the end of the day, as long as the dishwasher still works, we have no need to replace it yet. Buying a new spray arm is significantly cheaper than upgrading to a whole new machine. And, just last weekend, my dad replaced the DW's circuit breaker with a new one. The old breaker just kept on tripping, particularly in the middle of a cycle.
My new house has a Frigidaire dishwasher and has the conventional upper and lower sprayer arms.The washer works just fine for me.The only non Frigidaire appliance in the kitchen is a Samsung fridge.So far works just fine.All of the appliances were new as of 2022.
CycleSync™ is mumbo-jumbo that the pod "activates the right ingredient at the right time in the dishwasher cycle to revolutionize dishwashing and deliver an intensive clean" ... as if part of the pod won't dissolve until it knows it's at the correct point of the cycle.
CycleSync is purely marketing. It all dissolves at once, there is no pod that magically knows where abouts in the cycle the dishwasher is to release at different times.
Of course, the general public believe it and think they need the most expensive tablet on the market which equals sales which equals profit :).
Regarding Frigidaire
From my experience Frigidaire seems to be good. Actually my local appliance technician said that his recommendation for a new fridge or stove today would be Frigidaire which I'd definitely consider. I really did liked the 2004 Frigidaire dishwasher my grandfather had until the cabin flooded, I wouldn't have minded another Frigidaire dishwasher for that place cause one of my uncles owns one for over a few years now and works well but it got replaced with an LG.
Oh my, I don't know why they keep making that silly OrbitClean arm.
Electrolux is frustrating.
I have their washer/dryer left over from previous homeowners, and they're actually amazing machines.
A friend of mine swears by her Elux washer/dryer set.
The microwave over the range I got a couple years ago is a Frigidaire and it was the best looking unit at the store for the price, had 400cfm hood velocity, highest for OTR at the time, and the only one that had two LED lights. Even the luxo-KitchenAid OTR micro had a dinky single incandescent light.
I've had a couple basic Frigidaire dishwashers in apartments. All performed really well, ..... except around the time the detergents were reformulating phosphates out. That REALLY did in Frigidaire dishwashers I think harder than other makes.
But even now, if you need a budget dishwasher, you can bypass the silly orbit arm and the lower end Frigidaire dishwashers are pretty nice, and even have turbidity soil sensing now.
They seem to have good reviews online, and if not abused, could probably go a good 8-10yrs.
I'd certainly get a budet Frigidaire dw at this point, over a budget Hotpoint/Haier dw.
The swap to the standard Frigidaire wash arm is absolutely the right thing to keep that machine going for a while longer.
Finish CycleSynch is a marketing scam, like others have said.
If you look at the ingredients, they're hardly any different than the other Finish products. It's the same PVA wrapper. Their "claim" for cycle synch is the enzymes get to work while the main wash heats up to temp. Where once it's hot, the enzymes die and the regular soap does the rest.
That's it, and that's literally what every other enzyme detergent does on the market.
With that said, Finish detergents in general, for the time-being, I think are better than Cascade, for the water in my region. And they don't foam nearly as much as Cascade.
I think Cascade Platinum is still the better choice, however, if you have heavily hard water, like over 12+ grains, it does a good job still.
A closer look...
So today, I informed my dad about this issue, and I removed the spray arm so we could take a closer look at it. He found out about two things. First, the metal on the bottom of the OrbitClean end had split apart, so it's grinding against the plastic on the arm.
Second, the blue plastic has partially melted. With these two issues figured out, he deduced that the spray arm is not actually spraying out of the tips, and is instead spewing water in no particular direction, like a hose that hasn't been fully attached to a sprinkler. This is what actually contributed to the arm either turning slowly or getting stuck in one spot.
When I suggested we replace the OrbitClean arm with the traditional one, my dad rejected that idea, asking "Why change the racecar's formula?" (Apparently, this is an idiom meaning to make a substantial change to something.) So he himself ordered a new OrbitClean arm from Amazon; it'll be here in a couple days.
Who knew that a split OrbitClean end resulted in such poor washing performance? It pays to take a closer look at some things. But that's OK, we have no clue just how long the spray arm has been doing this for. Once the traditional arm arrives, I might just send it back.
Reply# 5
Concur regarding Frigidaire appliances.
I once owned (3) all fridge Kenmore refrigerators manufactured by Frigidaire, the reason why there were 3 of them is that the original unit was replaced by Sears under the extended warranty, which I wisely purchased upon buying it.
All 3 suffered some sort of sealed refrigeration system failure within a years time, enough for me to swear off any Electrolux product thereafter.
The 4th replacement unit was a reliable Whirlpool conventional top-mount fridge, I had told Sears that I did not want another Frigidaire at all.
I recently purchased a new GE french door fridge, a Frigidaire was completely out of the question, besides they don't produce a model I was looking for in an all white finish.
The Whirlpool is now 20 years old and hasn't failed me yet.
And they’re barely improved since then.
kalanikaau1- you’re right on the money. My Frigidaire fridge made it barely 4 years before it broke in such a way that the labor to repair it exceeded its value. And beyond that it was not well constructed, the cavity was slightly too wide for the shelves and they were millimeters from falling down.
I’ve replaced all the Frigidaire appliances that came with the place. While the rest didnt fail, they were at best simply cheaply built and at worst remarkably annoying and unpleasant to use.
I have two Frigidaire appliances...my gas stove and my dryer I bought for $20 and repaired for $20. I got it because it has front controls and I wanted to put it on a pedestal next to the Miele washer. It works fine enough but it just tumbles too fast causing clothing to stick to the drum instead of dropping through the heat stream. The sensor isn't all that great either. I always have to turn it back on for 15 extra minutes. But it still works since my repair. My GE never had any trouble drying anything even on low heat set for sensor dry...everything was dry when it stopped. It's now the backup dryer in the outbuilding.
New Arm
As promised, the replacement spray arm arrived late this afternoon, and I wasted no time installing it (after unloading the clean dishes, of course). This is a generic arm that came from Amazon (no reviews so far), arriving in a plain brown box. It was a bit tricky to install (the white piece that goes onto the dishwasher is a little more loose than the old one), but now the arm is in place, nice and snug.
I tested the arm by running the dishwasher, empty, on "rinse only." Right off the bat, I could tell a difference in the noise; there is a much more prominent "swishing" sound, a product of the OrbitClean end spinning.
I'm glad to have this spray arm issue taken care of (so far, not sure how long this generic part will last). I'll give the DW a workout just by loading dirty dishes without pre-rinsing them first. Off to wash!
https://a.co/d/hliAyND
Heh, forgive me for chuckling about this but your dad who insisted it must be the same design, is ok with a generic, non-oem part?
Ok…..
Who knows! The quality on the oem orbit arms is so spotty, this generic might outlast the old one!
Frigidaire dishwasher orbit, clean, lower wash arm
Hopefully the generic arm will work, we're going to continue to fix these by putting in the simple basic Frigidaire arm.
Generic parts are destroying a lot of appliances. People are replacing original parts with these inferior parts and then the machine breaks again and they're throwing away the machine. It's even worse when they've paid big money to have somebody install a new heating element in a dryer for instance only to have it stopped heating again within a year. And then the entire Appliance is scrapped.
At least with the lower wash arm if it fails, you can just replace it with the real one, and I have seen some generic parts that actually work for a while so good luck keep us posted.
John
Update...
Here's my status report on the generic spray arm.
Initially, on the first few washes, the arm did very well, getting the dishes cleaner than ever before. But unfortunately, things quickly took a turn for the worse.
The last few nights, the dishwasher had gotten a bit louder than before. I quickly realized that both the bottom white piece and gray tube, which twist and lock onto the lower post of the DW, are not very snug, so these pieces gradually twist into the unlocked position during a cycle. This makes the arm very wobbly during operation. I even tried using a drill to sand down the plastic on the locking piece, but that didn't do very much.
Just last night, I started the DW like usual and went upstairs. When I came back down about an hour later to check on it, my socks got wet. The DW was leaking like a sieve, all over the floor. I had to soak up all that water with a couple of bath towels. I then opened the DW, repositioned the spray arm and closed the door. The leaking mostly stopped, but the wash water got all sudsy. So I stopped the cycle during the final rinse and restarted on a normal cycle without detergent.
After soaking up all that water, the kitchen floor had warped in a few spots. Laminate floors and water are a dangerous combination.
Soon, I discovered that this new arm was showing the exact same symptoms that the original one did (staying in one place mid-cycle). Combined with the lower pieces coming loose, the arm would rest on the heating element, further exacerbating the problem.
Today, I removed the generic arm and took a closer look at it. The plastic had gotten a bit melted and even split open. And the OrbitClean end had gotten seized up, not to mention the metal piece started to split apart. Not even a whole week later, this generic arm is already having issues. No big surprise here.
Fortunately, I hung onto the original spray arm and its two other parts. After explaining the issue to my dad, he suggested that I pull a switcheroo, by taking the OrbitClean end off of the generic arm and putting it onto the OEM arm (in lieu of the old, split and melted end) to see if it works better. If not, we might just have to return the generic arm. I'm hoping that the basic Frigidaire arm will arrive tomorrow, like Amazon promised. I just want a good, reliable dishwasher with a functional lower spray arm.
