Betty is Back with another Full Cycle Video the '49 ABC-O-Matic
Oh, if only to have a machine with an overflow rinse. I watch my Maytag start spinning and pumping out…. And I watch all of that scum just settle right in to what used to be my clean laundry. Sigh. Everything degrades.
That's odd. I heard that spin-drain prevents lint/scum problems. ???
Signed: Goofy Glenn
Signed: Goofy Glenn
Maybe, to some degree? But I’m not sure how any machine that does not overflow rinse could prevent the stuff floating on the rinse water from settling on to the laundry as the water is drained.
I also have a Whirlpool from the same year- 1984- and it essentially does the same thing, just without spinning at the same time. Water level drops, and the stuff on the surface settles on to the load. 🤷
Keith
I recall an advertising graphic that illustrates Whirlpool's premise for neutral drain reducing lint/residue atop the load is that the drain port in the outer tub has the water level in the outer tub drop slightly faster than the level in the spin basket, which has an effect of pulling water through the perforations of the spin basket which in turn has effect of pulling floating lint/residue out through the perforations to minimize it from settling onto the clothes.
Signed: Goofy Glenn
In my experience neutral drain leaves scum rings around the agi and tub, and anything floating on top of the water is strained through and thus redeposited on the clothes. Spin drain has always provided me with the best results.
Which brings up the interesting point that the original WP direct-drive design was spin-drain, and the question of why'd they go to the effort to develop the Rube Goldberg neutral-drain mechanism if spin-drain is superior.
Signed: Goofy Glenn
Signed: Goofy Glenn
I remember being told by a repair tech it has to extend the life of the clutches. Not sure if its true. Ultimately, I'd like to know Whirlpools thinking, I wish I could have been the one listening to engineering decisions being made.
I suppose it is possible that the spray rinse could rinse that stuff clear through the clothes and out of the basket..,
You now, you've gotten me thinking again. When should the spray rinse begin? I've actually been thinking about having them start just as the clothes start being pulled up against the basket wall vs after the machine has reached full spin speed for some time.
Spray starts at 13:01:
Kenmore Ultra Rinse System:
15:34:
