Worst *New* dishwasher available?
michaelz08
Sep 17, 2024
101
Elmhurst, IL
I found this forum because the dishwasher of ill repute series came up in a google search -somehow- and I was enthralled. I poured over those threads and read every comment. Learned a lot about the history of the DW market and about companies like D&M or WCI that I’d never heard of… or would’ve had a reason to.
Just for the sake of entertainment, what is in your opinion the worst dishwasher on sale today, brand new? Let’s limit it to models that are currently manufactured, not some new-open-box unit on sale in an obscure store that was made in 1971.
And… can this please not turn into another “ALL MODERN DISHWASHERS BECAUSE OFF SMALL PUMPS THAT ALTERNATE ARMS” calamity.
I’ll start off- the BOL builder grade GE is a miserable machine. It’s so loud for all the wrong reasons, the bottom rack angled-sideways tines seem to fit nothing properly (I really tried hard), and if the design goal was “make it feel as tangibly cheap as humanly possible” then they aced it. The filter gums up in a matter of a week, it sucks at staying clean. And it cleans… OK at best. Could be worse but I’d say below average these days.
i used to think Frigidaire was the worse-cheap little brushed dc motor and about 100% fail rate door switch,but i do not know if they wash ok.In all the bad FD dishwashers i have junked,the PMDC motor was in decent working order though. PM "wet rotor"dishwasher pump motors seen to only last about 5-8 years in typical service:the water lubed ceramic bearings wear out and pump grinds to a halt.Do not wash potatos fresh out of the soil in a wet rotor pump dishwasher! :) These wet rotor pumps are often cheap and easy to replace whe they wear out- if not deeply embedded in the machine...
The wax motors that controlled some features like dispensers and wash one level only used to be some trouble. I don't know how many models still use that, or if it has been improved.
GE and Whirlpool still make several good performing machines. Newer model deficiencies can be thinner racks. I avoid racks that are not coated with nylon. Bosch, are very well rated. As for LG and Samsung I don't know much. Average life of a daily used machine is 8 to 10 years. That is before repair costs are too frequent and costly. Pump motors, control boards, etc.
My vote goes to... Whirlpool! Puny pumps that mist your dishes and take 2-3 hours, flimsy design, and don't get me started with the stupid alternating wash arms.
My same (former, it stayed in the house) whirlpool with puny pumps and alternating wash arms cleaned my dishes well and reliably for nearly 6 years… to each their own.
GE, Midea, LG, Samsung, Frigidaire. I happen to have a new GE as well, my apartment complex installed it a year ago and the racks are ALREADY RUSTING. I kid you not. It really struggles to remove soils that are stuck on, as to where my almost 20 year old whirlpool portable has no problem, because of the difference in water pressure coming out of each arm from a different power plant, I mean these new dishwashers use fish tank motors compared to the larger induction motors they used to have 20+ years ago and the difference is notable in sound & cleaning performance.
But yeah, very very cheap machine terrible quality, the door is entirely plastic & feels sort of like a toy dishwasher you’d buy for your child off Amazon. If I want to do a Sani cycle or hi temp wash, the machine runs FOUR pre rinses which is totally unnecessary, and during the final pre rinse it pauses for about ten minutes I’d assume to heat the water but then it drains and refills. And another stupid thing is this, when it drains, it doesn’t drain the little amount do water it has inside in one shot down the drain, it drains a little bit, pauses, and continues draining the remainder, and I’ve heard that’s because the drain pump can overheat if it’s on for too long well here’s a novel concept why can’t they just make a damn drain pump that can drain the whole tub in one shot without overheating? And this is the case for pretty much all new dishwashers our 2019 Maytag even does this. I don’t use this dishwasher that much maybe once a week at best, if the whirlpool is full of dishes that I haven’t unloaded then I’ll start loading the GE up and use that for the next cycle and Vice versa, by the time I move they will have to replace the dishwasher again cause the racks are getting very rusted.
Before I moved here I had a GE portable and that was a really good dishwasher, but it was made by Haier and that machine was so much nicer and had better quality than this hunk of junk, surprisingly it didn’t alternate arms either like my new one does. I got it for 75$ which is a hell of a deal since it was like a thousand dollars brand new just a year or so before I got it and it had nothing wrong with it other than it was missing the wheels which I ordered, I wish this one was like thsy cause it was actually quite decent and the interior looked just like a Bosch and performed like one as it had a heater built into the pump instead of a heating element, I miss that machine.
I'll second what you mentioned in the OP.
The BOL builder grade GEs and Hotpoints.
Primarily for their racks.
Their layout looks terrible, and they're vinyl racks that once they knick, they rust really quickly.
They're also flimsy AF, but perform well.
I used to say Frigidaire but I've been liking them more lately.
They've quietly improved their reliability and they're always affordable with good features and decent performance.
They've gone back to the leak-proof wet rotor pumps, vs the brushed DC motors they used for several years like GE (before Haier) which would leak from the bearing after just a few years.
You have harder water out there.
Worst new dishwashers I would give my vote to the basic plastic tub GE dishwashers as well. They are just plain cheap a property management company. We work with uses a lot of them.
Also tied for poor quality is the basic Frigidaire’s and the basic Bosch dishwashers they’re just cheap. They actually work pretty well but they look like crap inside.
The basic whirlpool dishwashers are also pretty flimsy looking, but they actually work quite well, and Jerome will be impressed because they don’t do an alternating wash. They wash both arms all the time. I’m surprised he hasn’t bought one yet, lol.
John
Also tied for pork quality is the basic Frigidaire’s and the basic Bosch dishwashers they’re just cheap. They actually work pretty well but they look like crap inside.
John L
Those basic whirlpools I am alright with. Kinda flimsy yes. They use the last gen wash system, which was pretty decent overall, and their racks are straightforward. And since they use the same rack designs Whirlpool has used for over a decade, easy to replace them with nylon coated ones if they rust out.
You’re not pre-rinsing or using too much detergent right? That’s a really short time for rust regardless of coating.
nope. Regardless, racks should never rust within less than a year of use from brand new.
Again, don't think there's such a thing as a bad DW per se, just a question of price and needs.
If you run the DW after every meal on the heaviest cycle - I don't think any DW will not perform at least tolerable.
And if it's free, tolerable would be all that I ask for.
But if you pay 300$ for a BOL GE, why not get a used machine for that price?
I think most ELux offerings in the US are just not worth their price. You can get a BOL WP machine for about the same as a BOL Frigidaire, and that will run laps around it.
In the mid range, there are some WP machines that are just speced pretty BOL for their price. They will perform fine - but you'd get a better deal with an entry level Bosch or MOL LG.
Same goes for Samsung - LGs DWs are usually just a better choice, especially given Samsung's DW track record.
In the TOL range, as much as Miele just has unrivalled quality, I don't think they are a good deal what so ever.
A TOL Bosch or KitchenAid (depending on which racking you'd prefer) is just a better deal - unless you really want that high quality feel. (I don't know why or how, but NOBODY makes a DW door feel so weightless yet high quality as Miele.)
And what would you want from a DW?
A good sensor cycle is worth a lot. So is quiet operation. And a full quick cycle (1h wash or similar) should just be standard today.
Pump duty cycle may or may not be a factor. DishDrawers (my 22yo speciman, leastwise) drain in "spurts." A fill is ~0.8 gal. The pump duty cycle is clearly not the reason being that it has only one (reversing) pump/motor which runs continuously during the recirculation periods, including during water heating. F&P washers (toploaders, I can't say about their frontloader models) pulse the pump during drain until the water drops to defloat of the basket. Lint flushing is the stated reason in service literature, so perhaps dishwasher drain pulsing is related to flushing of soil particles.
Perhaps concern of prior usage wear and to get a warranty.
Yes, agreed. A dishwasher is one of those things that you either need to be like us and A) are knowledgeable about the various models and their shortcomings, as well as how to fix them cheaply on your own or B) want to have the reliability of a warranty. Unless it was a screaming deal (like the $100 Kitchenaids I often see in my area for one reason or another), it’s hard to recommend a used dishwasher to a friend especially when they can afford a new one.
Used built-in dishwashers
Overall, there’s not a big market for used built-in dishwashers as there are for washers, dryers refrigerators, and ranges.
Many people don’t consider a dishwasher a necessity, especially if you’re poor and have other necessities that are more important to you.
We do sell a few used dishwashers every month. so many dishwashers hit the scrap piles it’s unbelievable
and many can be fixed easily. Sometimes we use two dishwashers to combine and make one great one
If we sell a used dishwasher, we give an installed price usually between 350 and $500 delivered and installed with a one year full warranty, including removal of the old dishwasher. Usually, most of the dishwashers are fairly high end.
People are quite picky about dishwashers. They want them in perfect condition. Don’t blame them.
We have a lot of customers that want to use dishwasher just because they’re environmentally conscious and don’t like the idea of buying a new one when there are so many used ones going to the crusher.
John L
I mean - at the price point of 300$ I mentioned, you barely get a new one anyway.
Getting a brand new BOL WP, Frigidaire or GE vs maybe spending 100$ less, getting 6 months of warranty (or whatever ever, many used stuff stores for appliances give at least some warranty coverage) - I think going used can be an option.
John L
Well back into the last century when I sold used appliances, I learned the same thing. Generally, if someone wanted a dishwasher, they just bought a new one... I might have sold a handful out of every few hundred ranges/washers/dryers/fridges. I suspect a trash compactor might have been the only thing that would have sat around longer. As far as being "environmentally concious", I've always suspected those tests that showed a machine used less water than hand washing compared them to people who turn the hot water on when they start the dishes, and let it run until they're ready to start drying the batch... I grew up taught to turn off the lights, don't leave stuff running when you don't need it, etc. We had a well pump, so every drop of water that we used cost money to pull out of the hole and pressurize...
Buying rebuilt or used major appliances
I think many of our customers are buying rebuilt because they don’t like the idea of all the waste related to buying a new one the packaging alone, shipping the product and parts all over the world, and then the old machine gets crushed and ground into bits and only a small percentage of it is really recycled. The rest of the plastic goes into landfill.
It usually makes more sense to use something that’s already been manufactured unless there’s a huge difference in the energy efficiency of the new product compared to the old.
In many cases, a product requires far more energy to manufacture it ship and install it then it will ever use in its lifetime.
There are other products like refrigerators were 70s frost free refrigerators using four times the power of a new one where it probably does make sense especially when you need repairs on the older one just to ditch it and get a new one. there’s no hard and fast rule.
John L
John
Good thing they run all at once.
