Are there any actual long-term reliability studies for appliances today?
michaelz08
Sep 17, 2024
94
Elmhurst, IL
It doesn’t feel like there is. Consumer Reports is obscure in the data they collect and it’s only from members, who perhaps aren’t always representative of the regular population. They’re really only good for performance testing, and even then it doesn’t seem like they’re perfect.
Yale Appliance “publishes” their results under the term reliability, but I take issue with that term as they only go back a single year. That’s more like “initial quality” than reliability. No wonder their rankings can be a little weird… LG beating Miele? Really?
Some repair folks make videos on YouTube, nothing consistently quality though. Ben’s appliances on YT sometimes leaves me scratching my head.
Any thoughts on all this? Any other sources people find to be worthwhile?
Long-term major Appliance reliability studies
Hi Michael, other than consumer reports there’s really not much, and consumer reports while helpful is quite flawed. They only ask how many times the appliance is broken. They don’t really take into the severity of the repair, etc..
I think consumer report should also ask what your last dishwasher was, and how long it lasted for for example that would give some idea of longevity that people keep an appliance.
I don’t see any problem with consumer report data being limited to their readers. They have several million readers, although their readers tend to be a little more affluent and better educated than the general population, I don’t think it should affect the ratings too much.
Very expensive high-end brands are going to have many more warranty calls, when people pay that much they expect a little more.
High end appliances are also made in more limited numbers and do have more problems initially at least.
I get a lot of information from my customers. I’m always been very analytical and analyze Appliance life and repair rates, I’m always asking my customers how long the machine lasted what problems they have with it how many people are in the house how many loads a week they do, etc. so I get a fair idea of which machines hold up better than others.
I do wish organizations like consumer reports would actually take the Appliance apart and see how it’s made. You can tell a lot. I had to put a heating element in a five year-old Electrolux dryer today. What a piece of junk. It’s a pain in the ass to get together in part half the screw strip out you certainly wouldn’t be able to take it apart and put it back together five times, this type of thing would actually be very easy for consumer reports to analyze, but I don’t really think they care about long-term reliability anymore.
If you look at Speed Queen laundry appliances compared to almost any other, you can see that they’re designed to be repaired the front panels come off of everything, almost all gas dryers today have to be completely disassembled to get to the gas burner Speed Queen take two screws off just like old times and the gas burner and such as right in front of you.
Changing a door boot on a Speed Queen front load washer is a simple task, changing the water pump on the front load washer only involves four screws and two simple hose clamps, for example. So it’s easy to see why the average Speed Queen will probably last twice as long as other machines.
John L
Short answer: No, not really.
Long answer?
I worked in engineering at BSH in the built in cooling department.
As an engineer as general, you are taught do design something as long lived as necessary, yet as safe as needed. The saying "Everybody can built a (sturdy) bridge, only an engineer can barely build a (sturdy enough) bridge" is pretty damn true.
As a company, you know exactly how long you have to have appliances last to fullfil your goal.
You know exactly, what a customer tolerates. Which failure rates are acceptable, how many customers you can stand do loose in a year etc.
And your job is to hit that number as closely as possible, for as many use cases as possible.
Of course, a higher end manufacturer has more of a BOM cost per appliance that a BOL manufacturer - but it's not that different in many ways.
All you know is that if you have small margins and your appliances last to long, you'll be out of business soon.
If your margins are great, but you sell 2 year appliances, you'll be out of business aswell.
Your customer knows that if you pay BOL prices, they won't get a TOL product - so they understand a 300$ washer will probably not last as long as a 800$ appliance.
So the manufacturers know how long their appliances last, pretty damn exactly, and they know what their targets are.
Those numbers exist - but getting them is EXPENSIVE. The place I worked at had an entire department with dozens of employees and probably the same number of thermal chambers and even more test stands just to validate that the goals are met - anything that lasted to long could be made cheaper, anything that broke to early had to be reinforced.
That's why repairing modern appliances is a gamble - if one thing breaks, the rest isn't really designed to last longer than something else.
But because those numbers are expensive to research you don't want them to be out there.
Your competitors DO buy your appliances, test them and validate their designs against those.
You DO NOT want them to get those numbers for free.
And who does pay for that research outside the companies?
No one.
Again - we are talking DOZENS OF MILLIONS A YEAR for one product category at one manufacturer.
Getting the same empirical data is just not economical outside the companies.
Our consumer magazine does durability testing primarily on washers. They did once on dishwashers as well, but that didn't really turn up anything. I remember they reported wheels coming off on cheaper models - not much else though.
For washing machines, they buy three samples of each model and run it through 1,200 cycles, alternating between a boil wash with powdered detergent and Rinse/Spin. For each run, the drum is loaded 3/4 full with cotton sheets.
In 2022 the 1,640 cycles were run, before that 1,840. Back then, heavy work overalls were used.
I don't know why the test was shortened. Probably money, maybe because most washers pass the test scoring Very Good or at least Good anyway...
I have older issues of the magazine and back then, only a few washers would pass without issues.
I know one reason Test mentioned was longer wash times.
If a cycle takes twice as long, running the same number of cycles just takes longer.
There's a video for a washer test done in the 90s by Test. There were a BUNCH of failures back then.
But about 2500-3000h at the low end is typically what you would expect for stuff like washers, dryers, DWs.
That's something in the range of 1000-1500 cycles - or 5-8 years in a typical home.
henene4 has the correct answer. I talked to an engineer at another company, and said almost verbatim the same thing.
You cannot make a $500 last long unless it was pretty much a motor and agitator in a tub - a very, very simple machine, that would not pass DOE standards.
The worst part of this is that consumers have pushed the companies often into this problematic situation. 50 years ago, appliances were built to last, BUT THE PRICE TAG WAS HIGH TOO. A Maytag WD set would last ~20 years, but then its cost was higher than the most expensive toploads on the market today (well beyond a TC5 or TR7, even). Thats why they lasted - its why a TC5 generally lasts longer too.
There are tradeoffs, but the other thing is, there's a linear or near-linear relationship between durability and wholesale costing. To make an appliance last twice as long, it'll cost twice as much (at least on the parts side - not R&D, tooling, ect). So there's a point that improving durability is uneconomical.
For an appliance survey on lifespan. I've wondered about that. Consumer Reports has good-ish methodology in that they at least asked people about durability. But what I am thinking would make sense for a survey is asking for make/model/serial number of the machine, then using the MFG indecies for date codes to figure out the exact date of manufacture for every brand appliances to understand what is the most, and least reliable on the market. I think thats the closest we could get to a proper lifespan on the modern machine.
This is exactly what I try to tell people.
The engineers at these appliances companies could totally make a modern and efficient and reliable machine/s. But, they would cost like 1500-2000 dollars. I’ve asked family and friends before. If you could get a washer that you know would last 20 years? But would cost you $2000 now?
99% of the time they say “no way. I’ll buy 3 $500 washes instead.”
That’s it.
That’s the buying public.
That’s also the retailers, because they know their customers.
And in this tariff heavy economically tough time? $2000 appliances that are built like tanks are a non-starter.
I've seen quite a few $3K Kitchenaid and lots of $4K Bosch fridges not making it a full year from the complaints on Reddit. Both manufacturers drag their feet, sometimes for months on end, before fixing those issues. 30+ years ago, coughing up more money = longer life but not anymore.
I was taking about washers since I think it makes mote sense with them.
But with griddles I think I agree. Fridges from what some here call the golden age; the 1970s, the cost of midline fridges were about $350-700. In 2025 money, that’s $2,500-5,100.
So you can get fridges today for similar or less money than in 1970. But today, I think they’re using BOL cheaper components in all grades of models. So that $4-7,000 fridge tots really isn’t guaranteed to last. But, you get better warranties in the upper price points.
If you go up to $8-12k Monogram or SubZero units today, I think you still get better components and those units are better guaranteed to last 15-30yrs. With a better repair network.
Neither fridge is simple, though. Look at a KA or Bosch wiring schematic. They are unfathomably complex.
For $3,000 you could build an absolute tank of a fridge. But its not going to be a French door. It'd be a single door bottom freezer, top freezer, or side by side - not the popular less reliable French Door style.
And like John said, if you want a 30 year fridge, you can get a True Residential. They will last forever. But they are $15,000.
Heck, just look at a Sears catalog from 1991. Take a guess what these nice units cost after inflation in 2025? Inversely, they'll last a lon time. Funny thing, hunh.
The thing that I absolutely HATE is that even cheaper fridges and other appliances often have the same sensors, switches, etc... but rather than tie them together with a sensible wiring harness, they run everything into and out of a "smart" board. Yup, real smart. Now you've added a black box that will let you make the appliance fail at will. No need to wait for a switch or a motor to crap out...
