Hello all!
I have a KDI-18 (installed in 1980). Recently, it began not properly washing. We replaced the wash arm support as we thought that might be the problem because the spray arms were not spinning/spraying. That did not fix the problem.
Here's what's going on when running a normal cycle... water flows in but does not rise to the appropriate level as it should. We thought maybe there wasn't enough water coming in, so we opened the door and added additional water from a bucket. But withing a few seconds it drained out leaving just about an inch left in the bottom of the machine. So now I'm not sure if its a water inlet problem or a drain valve problem. In either case, the wash arms never spin and spray water.
The other odd thing - when it hits the drying phase, it drys for maybe a minute and then water starts coming in. And the basin of the machine fills (like it should during the wash phase). Then it continues to dry again. When the cycle is complete, I have a machine full of water.
Any thoughts? Faulty inlet valve? Or is something going on with the drain? I love this machine and already had a repair man out, but he had no interest in troubleshooting it.
Thanks in advance!!
Thanks in advance!!
