Update on my 1950 Frigidaire WO-65 Unimatic
vintageteddy96
Active member
May 26, 2022
31
Wisconsin
A small update on the WO-65, I have disassembled the machine and am currently cleaning up rust and plan to patch the small holes with J-B weld waterweld, then coat the outer tub with bath tub epoxy paint. I also removed the motorIMG_20251019_1218533[1].jpgIMG_20251019_1219458[1].jpgIMG_20251018_1922220[1].jpg/transmission assembly and drained the oil. I took apart the pump because it was making a scraping/grinding noise. The pump was full of mineral debris and the impeller was very corroded and I'm not sure the the impeller will be usable as it has a hole in it. The housing look okay though.
Looking good, you can seal that hole in the pump impeller with 2 part plumbers epoxy putty. It dries hard in about an hour and you can then sand it down to make the patch level. Does the motor start and run without issue?
If you need fresh pump impeller bolts...
https://www.amazon.com/dp/B07D5TLBKT
Thanks for the info, the motor does start and run just fine. I was also thinking about having an impeller 3d printed in case this one doesn't hold up over time although a 3d printed one probably won't hold up very well either..
I would (and may try someday) make a silicone mold out of the impeller then recreate it using hard polyurethane plastic resin. Would be in interesting experiment to try to see if it hold up for the long-term.
Another update, I got the machine put back together and somewhat working with some minor issues that still need to be addressed. The timer does not advance so the timer motor is not working, maybe a wire came disconnected and i missed it when reassembling or maybe the lubricant int the motor got hard with age and i will need to take it apart and clean it up. All the cycles do work when knob is manually turned. The top gasket was dry rotted so i need to find a replacement as the spin cycle sloshes water out where the top cover meets the outer tub where the gasket should be. If anyone knows a source for a gasket that will work that would be great. The water pump leaked after first reassembling, so I had to disassemble and re do my gasket and reassemble and now I think I have it sealed properly.IMG_20251104_2346353[1].jpgIMG_20251105_2345493[1].jpgIMG_20251105_2345551[1].jpgIMG_20251106_0134111[1].jpgIMG_20251106_0153403[1].jpgIMG_20251106_0216456[1].jpgIMG_20251106_0219132[2].jpgIMG_20251107_1550495[1].jpg
I use self-sticking closed cell foam that you can get at Ace Hardware or Home Depot, etc which you can get in the weatherstripping isle. Leave the original cracked gasket in place and stick the foam on top of the entire gasket. Be sure to get "closed cell" foam and not open cell. You may need to add silicone under the cracked gasket if water is still escaping from between the cabinet top and the bottom of the cracked old rubber gasket.
The timer motor most likely you'll need find a replacement. You may have luck oiling it, but I find with those old black painted round Ingraham timer motors they usually have an open in their windings.
The there is an open in the windings on the motor. I took it apart and found that the winding broke right where it was soldered to the terminal, I reconnected it but the is another open somewhere else so I guess it's time to look for a replacement.
If you find a 1960s Frigidaire washer timer you can use its updated timer motor. The updated motors fit almost right but it takes a bit of tinkering with a few flat steel washers to make it fit tight. They are much more reliable for the long run.
I now have the machine fully working! I found a timer motor that worked with a minor modification, all I had to do was cut off the mounting tabs. I also soldered on the connector from the original motor. I want to post videos but it says files too large. I might have to upload them to google drive and post the link.
    1.6 MB
