90's Kenmore/ Whirlpool Washer Maintenance
TAG
Active member
Bronze Member
Nov 24, 2025
39
Amazing amount of information on this forum! Also, scary to think how many appliances we own that fit into the "vintage" category -- scattered around various properties we have.
I'm looking for some advise regarding a Kenmore top loader. Model: 11092599200. Common setup except this washer and the matching dryer have the solid state control w/ touch pad. I bought them new back in the 90's and other than a few odd fixes to the dryer nothing but normal maintenance. When I used to travel a lot they were covered by the local utility so the family could get service if I was away -- that ended 10 years ago. I love the machines -- lots of settings and they are quick.
Last year the tub started to wobble violently and looking online all things pointed to either the 3 main springs and/ or the odd spring in the back. I ordered the parts from Amazon as it was this time of the year and we needed the washer working the next day. Also had a used 4 way control valve that I picked up on e-bay (It's NLA) to fix the three dispensers on the top of the unit that had stopped working. Upon opening it up I discovered the single spring in the back had cut through the bottom hole holding it in place and the main coil on the original valve to the dispensers had failed. Drilled a new hole and used one of the coils from the used part -- cleaned it up and all was well.
So here we are a year later and I'm thinking about some preventive maintenance. I did notice a small amount of what looked like rubber dust when I cleaned everything up last year. Nothing was very dirty and there was no oil anywhere. I returned the amazon parts as I could tell they were not OEM and the springs had odd ends. The only other odd thing about this washer: Every now and then it leaves a few dark spots on things. Typically sheets. Once or twice a year I will see a small smear on something -- or a what looks like grease on the bottom of the tub. It takes a lot to remove ?? I assumed there was some grease or oil leaking from the transmission and a bed sheet was getting under the agitator and picking it up. So yesterday I took the agitator off thinking I would see oil all over the place -- nope. There was a tiny amount of grease in and around the top of the shaft -- but it all looked cleaner than expected. I did notice a couple a bits of something lower down inside the agitator that I first thought looked like rubber or part of a seal -- not that but it was what would have caused the marks. They were tiny and I could smear them between my fingers (maybe 4 of them) ... almost like the stuff in a garbage disposer ??? Can you get strange buildups in the tubs someplace on top loaders --- we use bleach?
So here is my maintenance question. The unit seems to run fine. Not loud in any way, although I don't think as quiet as when new. My plan was to order a new motor coupler and figured I would replace the 4 springs. I was really thinking I was going to find grease under the agitator and need to replace the gear case and the brake and drive tube. (I have the spanner wrench and the basket block and nut). I do notice a small noise when the washer is full and the spin starts on slow -- if I had to guess it's the spin clutch starting to go. It's minor and no one would notice and it does not leave the stuff wet. But -- if I'm going to take this apart again I want to fix anything while it's open. What's the best way to proceed. Should I order a new brake and drive tube that comes with the clutch lining -- or keep it simple and just order the clutch and leave the drive tube and not try and take the tub off. ShouldI try and install a new seal at the top of the drive tube? The little white plastic guides looked intact and I did the cam things in the agitator last year as well.
wow -- sorry for the long post!
Maybe too much information above? Without a knowledgable person saying the Basket Drive is worth changing out. Will stick to the basics and just order up the 4 springs, motor coupling and a new clutch kit. Don't want to regret trying to separate the tub from the spindle and running into problem.
1995 top-of-the-line electronic Kenmore washer and dryer
These were great machines, as far as your questions you should either do nothing or take it all apart and see what needs replacing.
As an active tech who is still working, who is literally worked on thousands of these direct drive whirlpool built machines I can definitely say that it’s never going to need springs. I don’t think I’ve ever replaced a spring on one of these washers.
However, pull the transmission and pull the basket drive brake assembly if you like if the shafts are scored and worn through the plating and rusted then replace the agitator shaft or the complete transmission also replace the brake assembly and spin tube if it’s in bad shape at the top along with the top water seal in the center post everything and that should keep you from having major problems for a while.
I would only replace the drive coupling if it looks worn that type of thing can be changed easily at any time, even new OEM parts aren’t always better than the original parts.
Let us know what you find when you tear into it.
John L
Thanks for taking the time for a reply. Interesting about the springs and valuable to hear from someone who knows. The washer does not make any odd sounds although I'm not sure it's as quiet as it was when new. You hear it when it's spinning. Guess I assumed the springs got weak and putting in new would make a difference ... help with any imbalance.
As I mentioned in the long post. The only thing I ever hear that could be called "odd" is when the washer starts the spin cycle on the slower speed when it's full. It's not all the time and the washer spins fine/ fast (or looks to be). That's why I thought about putting in a new spin clutch. The washer has always been a bit loud if you opened the lid when it was on full high speed spin. It dose kick right back to full speed when you close it and does not seem to slip.
So a bit more advise. If I'm going to take it apart -- for the want of $100 (I can get a NOS Brake Drive Tube off e-bay for less). That would renew a major part of the washer and the two clutch parts. Is replacing just the "band & lining" on the clutch enough or is it wise to order up a whole new clutch assembly. looks like the Brake Drive Tube comes with the important clutch parts. If the agitator shaft is worn I will have to order that -- but I don't have to take the whole washer back apart for that.
My parts diagram shows two seals at the top of the center post -- I assume that is what you are referencing. They list it as part 356934 (seal, centerpost (2))
Thanks again ... This is a great washer (dryer as well) due to all the settings (that we use)
Best -- TAG
