Parnall D59 dryer repair because it's blowing its fuse
wobblewash
Member
Jan 24, 2026
7
This is my mum's Parnall D59 here in the UK (no date, but I think it's late 1950s/60s)
Recently it blew its fuse (13A one in the plug). Replacing the fuse and powering it on H3 (highest temperature) it started to spin up but after about half a second it blew again. We use an RCD at the socket but that hasn't tripped anytime (there isn't one in the house fuse box)
I'm a relative novice when it comes to electrics and see everything as an opportunity to learn (but I do know to be v. careful!) As I start to tackle this machine I'd appreciate any repair advice or head starts you might be able to give me.
The RCD doesn't trip, I think that means nothing is shorting to earth or current going anywhere it shouldn't be. Blowing the fuse would mean some component in the machine has died in a manner that it has no resistance.
The machine is relatively clear inside; I can identify a junction box, heating element, and a motor which drives the fan and drum. No signs of any burned cables or damage.
The fuse/RCD behaviour above might be enough for an expert to diagnose the fault.
For now my plan is to look at the junction box, check internals for health and no shorts (though this machine hasn't been moved in decades, and always left on H3). Then perhaps disconnect either the heating element to decide if that or the motor is the guity party. Any pointers appreciated! Thanks
    310.6 KB
    188.3 KB
    227.8 KB
    310.9 KB
Check for free rotation by hand of the belt pulleys, perhaps some careful lubrication is needed of the bearings to insure that friction is not causing stress on the motor.
As for the heating elements, inspect for any wiring issues.
Others here might have some more advice.
Thanks, so I made some progress today. I'll write what happened here because it seems a bit inconsistent, I need to think about it.
Vacummed fluff out while visually inspecting everything. The motor does spin freely.
Inside the mains plug the live wire was very brittle; but still intact, no visual sign of an actual short But it needed a refresh so I cut the cable back and re-fitted it neatly.
Obtained a multimeter and tested the fuse (the second one) with it and found it to have not actually blown(!)
Tested for any shorts to the chassis with the multimeter, none found.
Disconnected the motor from the circuit and found 8.8 ohm of resistance across it.
Disconnected the heater element and found 47 ohm of resistance across it.
Started up the dryer with the motor detached and increased from 0-H3, and the heating element glowed orange by the time it was H3, with no fuse problem.
On that basis, re-attached the motor. The drum rotated with no fuse problem. Progress! I thought. But now finding a lot less heat (if any) from the element.
So all in all, it feels like some behaviour is inconsistent. I've left it to cool to try again and hopefully make it clearer if the heating element is working.
I can see the device that 'looks' towards the heating element (see the 2nd picture). I am wondering if this is a thermal safety cutout that's been triggered (or even a thermostat?) Perhaps I will try and draw a circuit diagram to make sense of it.
Not very familiar with UK machines, but since it’s producing a little less heat, could mean one of the heating elements has burned out, or the safety thermostat is getting weak after many years of service.
It's a good start if you think that is a safety thermostat, I feel like that is likely to be a weaker link here than the heating element itself. I will try and understand the circuit; if that safety thermostat fails by shorting the connection or breaking it, and if it also stops the motor or just the heating element.
Just an update here. I tested it the following day and it behaved as expected with the heating element glowing. I feel something is intermittent here, which does point to the safety thermostat in some way. So I gave it a clean inside, checked all the connections were good (they are) and put everything back together and we'll see how we go.
One thing I noticed is just how much hotter the air coming out the exhaust feels compared to the drum itself, but I assume this is more the design of the machine than a fault.
Thanks for the help and suggestions!
Definitely sounded like the high limit safety thermostat was acting up.
Would try to keep this running for as long as possible, will be lucky to get 10 years of service out of a newer machine, if that.
between the v-belt drum drive and tensioner, motor that can be be disassembled for a cleaning and oiling, will probably last until the end end of time. May not be efficient to modern standards, however more than makes up for it in terms of reliability and longevity. Just a simple timer and temperatures, all that’s really needed on a dryer. ‘Iron Dry’ or ‘Damp Dry’ is just 20 minutes or so, dryness is simply selected by drying time on the timer, no electronic dry control or moisture sensor.
I will keep a look out for replacement thermostat. I've only encountered something similar on old boilers.
The machine may not be efficient, but what's worse is the amount of energy in the manufacturing of a new washing machine.
This one reminds me of the machines I have used in laundromat in the US, just a timer and a door you can open while the machine keeps spinning.
I do wish modern designers would learn from the "user interface" of these older machines. I get it that improved safety standards or economics necessitates the use of microprocessors etc. but nothing prevents a modern machine being as straightforward to use as this. You pause (or not), check washing, change anything mid-flight and it's trivial and instant to do so.
On some older dryers here in the US, the machine would stop whenever you opened the door, would start back up as soon as the door was closed. Other models had a start relay/door switch that would need to be pressed so it’ll start.
One feature that’s been standard on dryers for awhile here in the US is a thermostatic auto dry that goes by the out going exhaust temperature. Runs the timer when the heat cycles off, turns the heat back on as soon as the thermostat closes.
This is the wiring diagram to a Maytag dryer I have from 1974, uses double throw switch thermostat for the automatic dry feature. Surprisingly, accurate despite only be a thermostat that goes by the air temperature.
    107.6 KB
Mum was utterly convinced this one used to stop when you opened the door, but I can't see any wiring that would perform that function.
