Kenmore waterfall filter hose 91769
ladyk
Active member
Nov 22, 2014
43
Tacoma
Anybody know where I can find one of these hoses? Unfortunately mine broke at the bend where it mounts to the filter housing. Not much room to route a heater hose. Any suggestions are appreciated! Thank You!!!!
so you may have to get one of these connectors to shorten it and connect to the pump...
you could almost route the hose along the top as to not have to disconnect everytime you open the top, but for some reason it wants to dribble water towards the filter during the spin and saturate the load.....it has to hang inside just like the original...
hope this helps....shop around for pricing, but this will get you in the right direction...
http://www.lowes.com/pd_50367-712-D...rentURL=?Ntt=dishwasher+drain+hose&facetInfo=
I used a Gates Part# 28480 (Product #42611696). You cut it to fit on both ends. It is a bit tight on the fittings, but you can stretch it on without too much hassle.
Gates 28481 (Product #42611697) would also work but is a lot longer. Not sure how the these hoses will hold up to detergents and bleach.
