1930's CONOVER dishwasher...help!
perc-o-prince
Oct 23, 2005
5,199
Southboro, Mass
Thanks to Larry(CleanteamofNY) I now have a Conover Electric Dishwasher. I am fascinated by the simplicity. I have been trying to find out some info on it. History, time frame produced...how it works?? It is pretty straight forward but a couple of things have me scratching my head. Does anyone have any information on it. It looks very much like a Walker.
I will post some pics as soon as I can. Thanks again, Larry. It was great to visit you and see your washer collection. Better lock your doors or you may find your Thor missing!! :-)
Rich
Tom, Thanks. I did see that but there realy was not much info. I was hoping that maybe more information had surfaced. I saw that another member had the same dishwasher and his came with paperwork BUT he was looking to find it a new home. My hope was that someone on this site was able to get it and might share what they know. I tried emailing the orig owner but didn't get any reply.
Oh, Larry...I'll take what's behind door #1 !!!!
Rich
Conover Dishwasher Brochure dated 1930
In at least two previous threads, I had posted a scanned image of my Conover Brochure. The quality is not sufficient enough to read some of the words unless you save the pictures to your computer then enlarge the images yourself.
And Robert has requested new scans of the Brochure in better quality so that he can include it as a Picture-of-the-Day. However, I no longer have a functioning scanner that works with my present laptop computer.
The brochure is a folded pamphlet, which has a hole in the middle of it. When the whole thing is unfolded, some images are upside-down. So I scanned the brochure in sections, then used Windows Paint to reassemble it - which is what I previously posted.
Below are the individual sections that I scanned, in hopes that the information will be better to look at and read.
By the way, this is the only Conover Dishwasher material that I currently have.
Mike
What type of detergent would have been used in early dishwashers? Didn't dishwasher specific detergents first appear in the late 40's-early 50's?
Interesting early machine
Noted that it came in green, ivory and blue in addition to white. Wonder if Conover had their own foundry to make the cast iron parts, or if they were provided by American-Standard or other plumbing mfr.?
Did find it odd that it appears that the water is pumped out of the dishwasher section into the sink to drain. That would preclude using the sink side at the same time. Would like to see one in person sometime.
Conover plumbing
Thanks for all the posts, very much. I am wondering about that extra handle mounted up the sink backsplash from the dishwasher----possibly a hot water valve and the operator would control the amount of water coming in? Or was water controlled by regular faucet through that hole in the top of the drainboard/dishwell cover? Or were they modern enough for a solenoid and limit switch?
Many thanks for pics, now explain what you know, please. Thanks in advance--
Mark
As this was not a fully automatic machine, I'm thinking the lever may have been a multi-positon control. Perhaps you set it one way to fill, another to run, and yet another to empty out the water. I have a feeling the operator determined how long the dishes washed, as no timer is mentioned. I also assume it used regular soap flakes such as Ivory or Lux.
Maybe you're right. I took another look at all the pics, I'm gonna guess it has to do with pump valve open or closed. Maybe water was filled by person at spout thru hole, then either it ran with valve closed for propeller to wash or with valve open for pumping out water? I'll keep guessing until an owner gives us the real dope----and VIDEOS!!
It filled through the hole in the top that you see under the faucet when the cover is in place. That is mentioned in the picture in the lower right corner.
You could not use soap; it made too many suds. As has been discussed here previously in other threads, there were no non-sudsing surfactants until the 50s and those were not very good. Early dishwashers used a combinations of water softening agents, like STPP and others. Because they were not fully built detergents, early machine dishwashing was not like today. Food soil was quite thoroughly removed from the items before they were washed in the machine. The dishwasher with the water softeners removed the grease and food films. You basically washed in the left hand bowl and loaded the dishes into the dishwasher on the right for what amounted to hot water rinsing.
I want you to look back at that dishwasher tank. Do you have any idea how much very hot water it would take to heat that up until it did not cool the wash and rinse water? If you wanted half-way decent dishwashing, you had to run several changes of hot water into that tank to heat it before washing dishes. This is why most of these machines were almost more bother than they were worth and were mainly used for rinsing dishes that were already washed. Also remember that storage water heaters were not common in the 20s and 30s, so a house would have to have a good supply of hot water to use a dishwasher, although a home that could afford a dishwasher probably was wealthy enough to have a good supply of hot water.
It is correct that this machine had no timer. The control would have been wash/rinse or drain.
