1950s Crosley Shelvador
gizmo
Nov 17, 2001
2,586
Victoria, Australia
At a little second hand store I recently found the owner's manual for a 1950's Crosley Shelvador fridge. (note - just the manual, not the fridge.)
I will post pics of a few of the pages here.
One thing that interested me is the description of the "Automatic Defrosting" of the freezer compartment. It was not like modern frost free fridges today, where the evaporator is hidden in the back and cold air is circulated by a fan. It is a conventional freezer with defrost heating elements attached to the top and bottom plates of the freezer compartment. The elements are activated once a day by the defrost timer.
I have never heard of such a design before. Has anyone here used a fridge like that? I'd imagine that defrost water would drip on the food packages in the freezer during the defrost cycle, and freeze hard when the freeze cycle returns. How is that avoided?
Interesting also to note that it was assembled under license in Australia by James Kirby company - they also assembled Bendix front loaders at the same time, as well as the Aussie versions of Tecumseh mower engines, which were called "Kirby" engines here, later called "Kirby-Tecumseh." (We had a Kirby powered mower when I was about 11 or 12, it caught fire when I was using it one day, Dad put it out by shovelling sand onto it!) Kirby also made automotive components, and they still exist today, though a much smaller company mainly making refrigeration/coolroom components.
Here are some pages...
Chris.
Seasonal Control Damper / Page 8
Please answer one question:
I have a 1954 Crosley Shelvador which still runs.
It has that "Seasonal Control Damper" which I could never figure out. Poor Gram went to her reward without leaving the instruction manual.
What does that damper do? (See page 8).
Thanks.
(BTW, mine does not have the defrost cycle. But putting heaters in the unit was pretty advanced for that time...)
I love my CAPACIOUS Crisper. I'd have no other!
Hi Paul
The idea of the seasonal control damper is simple.
In this type of fridge, there is no refrigeration to the "fridge" compartment. It is cooled by allowing warmer air from the fridge compartment to rise up and circulate around the freezer compartment, when it is cooled it will fall back down to the fridge compartment.
The damper is just a flap which alters the size of the opening between the fridge and freezer. In winter the fridge won't need so much cooling so you can leave the flap closed. In summer you open the flap to increase the cooling effect. If you leave the flap open in winter, you might end up with frozen milk.
Chris.
