dld
I recently purchased a near perfect GE oven to put to use in an old house we are restoring. I bought it from the second owner for the past 45 years and she says the stove was in the house when she bought it. She was still using it. It had two burners not working and the small oven not working other than that it is perfect even included the plug in grill.
I repaired the small oven by replacing the old thermostat with a newer vintage Robertshaw switch works great and was able to adapt the old knob.
The left rear burner just had 2 of the wire broke off I am assuming from lifting the burner up and down to clean. I repair them and it is working great.
The left front automatic burner had 2 broken wires That I repaired but when turned on the temp was not controllable so I played with the thermostat switch but I believe the hydraulic sensor has failed.. After searching this forum and others I purchased a Robertshaw 5500-202M infinite switch to replace this thermostat but I am having difficulty configuring the wiring to utilize the original 3 wire burner and the griddle option.
I have reached out to Robertshaw tech with no help yet
Thanks in advance for your input.
Dave D.
Dave D.
