riverrat
Active member
I'm the repairman
Hello group, thanks for responses to Riverrat's concerns about her washer, I'm Peter, I'll be maintaining these for quite a few more years hopefully. I've replaced both belts with new maytag belts so I don't believe it's a belt noise, they are in like new condition. My ear, (not real reliable) says its coming from the bottom radial? bearing area but could just as easily be coming from the bottom of the tub. Its what I call... uuurrrrk uuurrrrkk urrrrkkk starting out with the spin and pumpout, keeping pace with the rpms and fading as it gets to full rpm. it did it with just water load while I was testing it. For the first investigation of the noise I removed the front panel and investigated the bottom bearing arraingement, removed and reassembled, the bearing is not obvioiusly washed out, with not too much play in it.
Spray lithium grease, under rubber deflector and on top of lower unit initially eliminated the noise but it is returning after a couple dozen loads, not with just water right now, but under loaded spin it still there but not as bad. I'm currently looking at the exploded parts diagrams and maintainence manual exerpts, yes the main stem and tub bearing don't look like fun. I need to find and lubricate the pads someone was speaking of next. thanks, I'll be in touch, Peter
