1960 Malleys Automatic 12
brisnat81
May 5, 2004
2,243
Brisbane Australia
For those that have been around a while, you might remember that 18 months ago, I found two of these machines. I've been working on restoring one of them, but it has been a slow process as they'd been stored on a farm for the last 50 years. This is a Horizontal Axis machine that holds 12 pounds of laundry. its a bolt down and has an inbuilt heater. Its cold fill only which for 1960 is pretty unusual.
Just before Christmas, Leon found another one online still in its original house, bolted down in the Laundry in Sydney. I went back and forth on getting it, and then decided it was worth it for the Blue sections, rather than getting the control panel on my existing one recoated.
The machine arrived a couple of weeks ago, and when I took the front off, we were amazed at how clean it was underneath. Other than lots of dust and some oil, the machine was totally clean. More surprisingly, after a quick once over, I hooked it up, plugged it in and it was running. When it started to suds up, it started to leak, but not too much. Then in the last week when I've been running it, there was a puddle appearing underneath.
Today I took the front and the back off and was determined to figure out where it was leaking from and had my fingers crossed it wasnt from the main seals.
It turns out that the rubber grommet the inlet valve pushes through was perished and that explained the leaking when it was sudsy. The second leak is from the drain valve on the pump. I managed to easily replace the grommet for the inlet, and with some work got the drain valve out of the other machine I have. It wasnt as badly perished, so now it just drips rather than gushes, the original valve was a pile of crushed rubber.
What makes this suprising, is that other than some rust spots along the top edges of the panels, the paint has cleaned right up, inside and out, with just some Dawn and Elbow grease. Its not quite brand new looking, but not too bad for nearly 60 years old.
I've attached some pics with the covers on and I'll work back through the process.
All going to plan, I'll look to bolt the machine down next weekend and then we can try a maiden wash. There wont be too much to see, but the machine is pretty quiet, other than the pump grunting away as it drains and spins.[this post was last edited: 2/24/2019-04:07]
Under the Hood
You can see the factory fitted Cork, its where a fitting can go to manually fill the machine with Hotwater.
You can see the pump on the back, it looks a lot like a Bendix/Dexter pump to me, does anyone have a repair diaphram repair kit for one of these, they might be prepared to sell? You can also see the oiling tubes, the three bronze bushes have a wick and an oiling tube, the manual advises to fill the tubes every 6 months. Depending on which literature you read, it recomends SAE 20, 30 or 40. Getting a monograde mineral oil these days is hard, I ended up with Vintage Motorcycle Shock absorber oil, with is SAE30.
From the front side, the left hand motor is the wash motor, the right hand motor is the Spin motor. The Wash tumble speed is 60rpm, spin is 380rpm. The large pulley on the right, is an overdrive clutch. The Spin motor idles until it switches on and then it disconnects the wash motor from the drive while it spins
The earlier model had a float chamber, this one luckily has a pressure switch, its much easier to work on and repair.
Bolt down Malleys washer
Does this reverse or is it unidirectional?
Loved reading the instruction booklet thank you so much for sharing with us :)
Happy washing and a video sometime please
Austin
Hi Austin,
It tumbles clockwise only. The Wash Motor runs from start to end, so it tumbles at 60RPM from the initial fill through until the loosen cycle after the final spin.
The only time it doesnt tumble is during the heating phase. You let it finish filling and then tumble for a bit, then when you press the white button on the thermostat, the wash stops and you get a soak period until the thermostat is satisfied and then the wash continues as per normal.
Cheers
Nathan
Beautiful machine Nathan! Very vintage looking, super cool.
The knobs, blue panel and nameplate also look very much like a Bendix Economat of the same time period. I wonder how Bendix was involved in this Malleys? It sure does appear like it was.
Pump valve spares
Dear Nathan love the machine and such good condition !!Mike King and myself were chatting on the phone and admiring the machine
I’ve just done up a Bendix Lt washer dryer and in the past I’ve done a Bendix semi auto with the bolt down fixings . The pumps are a pain to restore but I . Managed to get (from China no less) the similar valves. That worked for the LT model !!! Also they were as cheap as chips !!!
The problem I had is that the pumps are prone to corrode up time and time again unless you constantly use them !!If you search rubber drain valve seal on eBay (worldwide )it will bring them up . Message me
If you need any other help best wishes Darren
