ashaw86
David, yes you are right it is the Supco 3-1 same as the picture you sent me. This one is for 1-4-1/3 ho compressors. Indirect tested several times and only get a hum quickly then it trips the overload. I waited for reset and tried several more times thinking I may get it to start. No such luck. I also tried tapping with a rubber mallet, it’s hard to reach but I was able to tap some. Still has not freed up.
I will test it to make sure it isn’t an open circuit in the next day or so. My dad is storing it in his garage for me so I don’t get to work on it as often as I’d be able to if it were at my house.
I am also moving aoon that’s why I bought this refrigerator. I got the matching set walll oven, counter top stove, and range hood to go in the kitchen at the new house. I didn’t plan on a project but feel like I have to save it to keep the matching set.
Assuming the taint open circuit the last ditch effort of bumping it with 240 I’ll have to get you to explain the best way to do that since I’ve never had to do this. I am willing to try it though to save this refrigerator.
One last question, if I need to replace the compressor do you have an idea of what compressor would be best to look for? Thank you for all your help.
Evan
Evan
