Finished.....almost
Check out the console light, as yellow as any I've ever seen. There's good advice up the thread for cleaning it, but with the need for peroxide and UV light or sun, it will wait for a summer day, not now in Ohio.
This machine is back in perfect shape, with advice from Kenmore71Mark, John Combo, Dave Vovloguy, thanks to you all and others.
New heater element properly installed and checked, old one wrapped up for repairs, new hinges on the lint filter door, new paint on the entire front, it runs like a charm. The lights(console and drum) are wired together, they come on at the start of the cycle and whenever the door is open, they go out when you close the door or when the cycle ends. The origianl motor is clean and lubed, everything inside is cleaned and Rustoleumed, the blower and airways all lint-free. The vent needs to be cut through the wall to the outdoors, come summertime, along with the one for the D608 to the right. I only do gas dryers where there is a vent, I use electric for some basement heat and moisture until summer arrives and I can crawl under the front porch to cut through a vent.
Running like a charm, huge 29" cabinet monster of a machine, it's fine.
