1976 Frigidaire 1-18 Model WC stopped working
rapidry1000
Silver Member
May 21, 2001
240
San Francisco
Help! I need our fellow members advice. My 1976 Frigidaire 1-18 stopped working while pulsating a load of sheets. I turned the cycle selector to spin and nothing happens also. Is the belt broken? I have not removed the front cabinet panel and have not investigated further.
If the belt is broken can I get a replacement? For someone mechanically challenged, is it a difficult job?
Thanks for any advice.
First things first
Can you actually hear the motor running?  You're going to need to get that front panel off the find out what's going on.  A belt replacement certainly can be done if that is the problem.  The instructions are here on the website somewhere but I think I have a copy of them as well.  You must remove all of the hoses from the pump in order to replace it and loosen (but not remove) the motor mounting bolts.  Investigate further and let us know what you find.
I can hear the motor running and when I change the speed selector the sound is different for the slower speed. As you advised, I'll remove the front panel and see if the belt is actually broken. Thanks
It most assuredly must be the belt.  What you'll need to do is get the panel off, remove all the hoses from the pump (mark them if necessary).  The clamps are a pain to get off most of the time and I when I did this job recently I replaced them with easier to manage band type clamps that tighten up with a socket or slotted screwdriver.  If you use these be sure to get them good and snug, but not so tight that you would break a pump port.  Then you will locate a socket of the proper size and loosen up the motor mounting bolts.  Attached is a diagram on this.  The belt I bought was from ACE Hardware and it was a 3L310 General Utility V-Belt, ACE part number 22523, made by MBL.  You will remove the broken belt and then thread the new one on over the transmission and up around the pulleys.  I put mine on the motor first, it is more difficult because you have a tight tolerance there, but it can be worked over the top of the motor pulley and around the pulley, then thread it around the transmission pulley, while doing this you may need to move the motor in (to the left) to give some slack for the belt to get over the transmission pulley.  Pull tension back (according to the instructions) and tighten up the motor mounting bolts leaving 1" of in/out deflection on the belt, you want it neither too loose or too tight as it will over stress the pump/transmission bearings.  Please let us know if you need any further assistance and best of luck :)
