rdm81
Hello, I’m trying to troubleshoot my 1994 Whirlpool washing machine’s issue, to make sure that I buy the correct part or if I should sadly just replace the machine. I’m pretty sure that it’s the timer, but it might be a wiring issue. All the cycles on the machine no longer work. For example, the heavy duty cycle will fill and wash the clothes, and the timer will advance, but it will continue washing for the entire 30 minute cycle. The Normal cycle washes, drains, spins, rinses, drains, does a spray rinse, but not the final spin. The delicate cycle washes, then drains without engaging the pump, causing the water to drain and slosh over tub as it spins, goes onto the rinse cycle and stops with the tub still full of water. I haven’t tried the permanent press cycle because it was water, so I’m not sure if it works properly. The issue started a few years ago, with the machine going into the spin cycle as it’s draining (when before it would drain and then start spinning) and sometimes stopping the final spin cycle half way to do a spin rinse and not do the final faster spin. The timer is $300 through whirlpool so I want to make sure it’s the right issue since I can’t return it after I’ve installed it. Sorry for the long post and thank you for any advice you can give me!
