Hi Everyone,
Somewhat "new" member here (I did make one post a couple of years ago in the Imperial forum). As you can see by my user name I have been, up to now, a fan of the Maytag Dependable Care washers and I have 2 of them on different properties (both only used by family). This one, which has had relatively light use and is in excellent physical shape has me stumped. It has started to make a squealing sound after agitating about 8 minutes - so the sound only appears in the last minute or two of the wash. It disappears when it spins and does not appear again in the rinse. Even if started right after one load finishes the next load is be the same - starts out fine, squeals the last minute or two of wash and is then quiet again. Belts have been changed and made no difference and there is no sign of any water leaking.
An appliance repairman who was in for another unrelated issue with my kitchen exhaust said he thinks it is the transmission starting to go. I took the front panel off however have been unable to tell if the sound is coming from the transmission or from underneath the machine where the belts and pulleys are. This does not seem like any typical symptoms for this type of machine. If anyone has any suggestions please let me know. If it needs a new transmission I will probably be replacing it with a Speed Queen. Thanks in advance for any help!
Video of the sound:
Video of the sound:
