2004 Maytag Neptune TL makes clothes smell
scottwhite98
Aug 25, 2022
Tomah
Hello all-
Inherited a Maytag Neptune TL from my widowed mother. Serial # comes back as a 2004 model. Everything seems to function ok...no odd sounds. I really don't like it. It tends to twist everything up, clothes smell like detergent, or, come out smelling all musty.
What is the trick to get this machine to clean clothes well?
Stinky front load washer
Try running some washer cleaner through it to get some of the gunk out of the machine.
In general you should only use a hot wash and a cold rinse setting on this machine for everything.
At least one and 10 loads should have liquid chlorine bleach in the bleach dispenser.
Use a good detergent always use an extra rinse setting.
If the machine is pretty smelly it may take a few months for it to start to smell decent.
John L
if this is the maytag neptune TL with the 2 rotating disks, there might be a bunch of mold or residue built up behind them. run a few cycles on the longest setting with bleach, it should do a bit of good to remove the buildup.
