cfz2882
While on the subject of small 2wd trucks,Will tell about mine incase anyone is thinking about one:07 Canyon,2.9 4cyl.,5 spd SL (base model)Great little commuter truck,i would buy another right away if something happened to this one
-yrs 04-12
-earlier models,~04,05,known for valve guide problems
-manual transmission made by Aisin
-mine wheighed in at 3420
-2.9 l,185 HP@5600 RPM
My only minor dislike about the truck is the "throttle by wire"seems to get comfused a little by certain throttle manuvers and can set up a goofy bucking motion...Also will sometime pull back throttle right after you boot it then resume desired throttle opening.
134,000 mi,totally reliable over 4 yrs I have had it except thermostat failed in open position.
-yrs 04-12
