Zanussi Factory in ITALY
keiththomas
Aug 12, 2009
112
Does anyone have the address I can write to in Italy so I can ask if there are pictures of Zanussi washing machine factory. This is the second washing machine after 29 years of the originaly S218T, now rotten away to be purchased. I e-mailed Electroluz but they said there was no details. I do not beleive them. I searched the internet without any joy
Zanussi
This is the adress of the historical washing machine plant in Porcia
Electrolux Zanussi Italia s.p.a.
Corso Lino Zanussi, 26
33080 Porcia PN
Italy
0039 0434 394800
www.rex.it
www.electrolux.it
Maybe you'll have more luck with Zanussi Cultural Centre in Pordenone
Centro Culturale Casa A. Zanussi
Via Concordia, 7
33170 Pordenone
Italy
0039 0434 365387
[email protected]
http://www.centroculturapordenone.it/centro
Hth
Cheers
Carlo
linked pic :
http://www.paginegialle.it/pg/cgi/mappe/build_map.cgi?cl=1&cs=4W02331611&cb=0&orto=1
thank you
thank you rex, this is great, I must admit the new Zanussi looks good but appears to take much longer then the old machines, also why are they cold fill only now thats no good
hot & cold fill Zanussi : Rex-Electrolux Sunny
Actually Zanussi makes the model Sunny RWFH12280W, for those who have hot water heated with solar panels, heat pumps or gas - wood pellets furnaces.
The machine uses the hot fill on Cottons 40-60-90 °C and Easy Care 40-60°C, while on cottons and E.C. 30° and tap cold it doesn't.
In case of protein stains that require a tap cold fill start, one can push the "water connection" button (2nd from right - orange digits )
Anyway the hot fill doesn't speed up this girl. Check Thread Thread Number: 26771 Candy washer : there I posted the spec sheet . The Sunny takes 155 mins while the Calima (cold fill only) takes just 5 minutes more
A closer shoot of the control panel is here :
http://www.rex.it/sunny/
to be honest ..
methinks those 155 mins are for the "A+A" cycle ("five to eleven" on the dial)
1st button from left is for spin speed (1200 rpm ---> rinse hold)
2nd button is for *prewash* or *quotidiano/daily* or *breve/quick*, where *daily* is halfway between *no option* and *quick*
