What is the WORSE washer you have ever owned
My worst washer
was the redesigned, make that ill-designed Gibson by Electrolux that replaced the single belt reversing tumble washer that was a combination of the White Westinghouse design and Italian motor, electronics and timer. The Gibson came out in the early mid 90s, I think, or the mid early 90s.
The Gibson had a round porthole door. It suds-locked horribly and shut off the pump before the spins stopped so that it started the rinses with a nice pool of sudsy water already in the tub. It really made me appreciate the performance of the Kenmore Dual Tumble washer with its powerful pump and no screwing around spinning.
My current Whirlpool
It's a POS, in 18 months bearing failed 3 times under warranty and all the tub assembly was changed. It rinses poorly and spends ages in balancing. It washes not at all well, compared to all the other machines I've seen. After all, was rated last (usually Whirlpool is there) in Altroconsumo reports last year.
1-18
In poppy red. I had a 1963 Imperial set from Frigidaire and was very pleased with their performance. I bought a new set in 1974 with the window in the lid. I was disappointed in the noise of both the washer and the dryer. At full capacity roll over was slow so I seldom filled it more than large. I traded it back with some extra money and got a Maytag set. The house was sold with appliances when I moved to the midwest. It wasn't a terrible washer, it gave me no problems, but it was my biggest disappointment.
I've not owned a bad one. I lived in a rental house with the index-tub Frigidaire in it that I didn't like very much. The worst one would have to be the portable that I use right now, but that isn't it's fault. It's 20 years old, so I can only expect it to need some repairs when used as much as it is. It also wasn't the fault of the washer that a replacement pump only lasted about a year.
Whirpool Cabrio - broke up a lifelong dedication to Whirlpool washers. I've gone completely to Speed Queen now. Cabrio suffered many error codes and eventually stopped draining, it was 2 months outside the 1 year warranty.[this post was last edited: 6/30/2010-14:00]
Whirlpool
Mid 80's BOL DD.
At the age of two it flooded my kitchen twice within two weeks. The machine washed fine when it wasn't flooding the kitchen. I replaced it a week later with Maytag Dependable Care twins, and got $150 in trade in allowance.
GE Adora.
My mother has them, not me, but I use them when I visit. They don't clean well, cannot remove cat hair, will not balance on spin at all well, and take effing forever to run a cycle. The whites cycle takes over 90 minutes! I can get cleaner clothes out of a Maytag A208 in a third of the time! The detergent dispenser drawer doesn't drain and must be dumped after every use too.
Take all the bad things about a front loader, compress them into one machine, and you get the GE Adora.
Dave
This is an Easy One to Answer
The 1967 Monkey Wards Signature/Norge. The transmission failed on that thing in barely a year and the whole machine made a terrible racket. It might not have been so bad if the laundry room wasn't right next to the den where we watched TV. That machine was less than 8 years old when it (God, I certainly hope) got krushed to smithereens. It sounded like a big rig driving through the house during its pathetic final weeks.
By far....
....the top loading Frigidaire washer in my Kenmore Laundry Center. It was reliable enough, but it had the straight vane agitator with the indexing tub....fun to watch but not terribly effective.
The 2.7 cu ft tub with that combination didn't hold much if you wanted clean clothes, and the weak spin, and the weak dryer made for a long day if you let the laundry pile up at all.
The least reliable machine we had was a 1981 Monkey Norge (replaced an ailing Rollermatic).....it went back after 4 weeks and 5 different repair calls to keep it from walking all over the place. The Kenmore belt drive that replaced it was still going strong 12 years later w/o a repair.
With out a doubt
Hotpoint WD440 bought by my partner when we were on a break.....noisy, cabinet appeared to be made from bacofoil....it dented just moving it back into place after cleaning behind it....to get a decent wash it took ages, spin balancing was a nightmare and if there was a big load of towels in it used to throw water out of the dispenser draw on the intermitant spin. Also took an age to dry a load. Did a dance when the pcb failed after two years.
A Hotpoint made Electra. Noisy, low performing and broke down CONSTANTLY. In the space of 3 years, it had 2 new door locks, brushes replaced and the whole outer drum replaced. It was just awful. My Mum got sick of it eventually and bought a Zanussi Jetsystem to replace it.
Actually, I'm going to supersede my last post, and say my neighbours Indesit Moon is the worst machine I have ever used. It's just dreadful. Lack of options, it takes AGES to wash, the water levels are ridiculously low. At least the Electra actually washed things.
Neptune - the washer that killed Maytag. At least 3 (or more - lost count) rubber boots eaten up due to mold issues, wax motor failure, then bearing failure on the washer and electrical death of the matching dryer ON THE SAME DAY. And that day happened to be day 2 of when we started potty training #1, so you can imagine what I had waiting to wash. And, to put sprinkles on the frosting of that cupcake, I was eligible for the recall/lawsuit settlement yet wasn't notified at all...and only found out about it 3 weeks after it closed.
Replaced that with a Bosch Nexxt 500, which has its quirks but is into year 5 now with no major or out-of-warranty failures.
Never LG again! As I written before.
I remember that thread....it came to mind and I heeded it when I bought my new washer. Thank you for sharing and sorry you had so much misery.
none.
Even if the GE Filter Flo and the Kenmore 80s series have their flaws on what comes to washing results compared to Euro machines, even IF the sink-top portables (the French "Calor", the British "Burco" and the German "Cordes") impeller machines have a lousy washload/water consumption balance, even IF I would only trust my loved Lavamat FL once it comes to really CLEAN clothes: I have tried them all and I would never want to miss any of them. They all have their own spectacular mechanisms and wash actions (and sounds, I could kiss them all for that ;-)
Talking about service calls? NONE of them, they all keep going strong. Some for 1 and some for 4 decades. Nothing whatsoever. Maybe a seal here and there, but that was it.
The only thing I once was thinking was: "what the F...... do they think? (they = the engineers) Just assuming 1-2 mins of wannabe rinsing theatre would do?" (I myself would have expected the inventors to wait at least for one or two full rollover cycles before rinsing is done). This refers to almost any classic toploading American washer. The first time I saw this in the US (before I owned any washer at all) was in the 80s, I thought: Goodness, down there some t-shirts are rinsed, but up here most of the clothes are only wiggled around a little in vain, floating about a bit for a good impression only and now suddenly everything is over and these gallons of clear water are pumped out (it got even worse when I saw the minitub GE: socks only rocking cozily in some foam with no washing action at all).... what a hooey! Do buyers believe that? My gosh.... these GE guys have stopped thinking halfways (this is what I thought that day, correct). While the GE FF is probably the best in soil and sand removal, the timer is a joke (long pauses, shortest useless rinse cycle ever)
A friend was over at my place, watching the GE: He said (in one of those looooong timer breaks): "hey, what's wrong? I got another song going in this jukebox! Want my money back!" He hit bull's eye, this was unspoken yet but very true.
Nevertheless: I do LOVE all my machines. None of them have failed me ever.
The Whirlpool Crapso! The parts were poor in quality, the machine really did not clean that well. Also Maytag washer with orbital transmission-small clothes basket, poor roll-over.
Hard to believe
Never really owned a bad one. The worst one I've ever used, but didn't own, was a 1970's vintage real Westinghouse; loud, clunky, lame spin. Have used many Whirlpool/Kenmores that I thought were clunky, inelegantly designed machines, but they did the wash and I've spoken to too many service technicians that think they're the easiest machines to keep running. Also, my first washing machine was a BOL Whirlpool and I will always cherish that machine. Thinking very hard here, but I guess that it's making me realize that choosing good appliances must have been important to my family, because no one ever just went out and bought some cheap machine to do the laundry. Also, haven't had a lot of experience with breakdowns(knocking on wood here). And, as discussed before, I have had the opposite experience from Pete with LG. I am very careful to mention Pete's experience, though, when I recommend the brand to people.
