Anthony:
The Model is SE120B
The Serial Number begins with '5320' which translates to Build Year of 1953, 20th week, which translates to the week of May 20 (plus or minus).
Disassemble and clean the pump carefully.
If you haven't already, hook up a hose from the water valve to a faucet and test. If plugged, carefully disassemble and carefully clean the valve filter.
The impeller is really in sad shape. And they are next to impossible to fine new. Generally, one needs to find a donor machine to get a replacement impeller.
The S-10 Mechanism Parts Listing (above) is virtually the same as the S-11 Mechanism used on the SE120B models. I don't have the SE120B listing on paper; I only have it on microfiche.
Mike
