Nice Collectible, But.....
....You wouldn't want to use it on good knives you really care about. This kind of sharpener removes a lot - a LOT - of metal from the edge with each sharpening. It doesn't take too long before your knives become really worn down, with the shape of the blade substantially changed, from this kind of sharpener. All sharpening removes metal, but for the sake of your knives' longevity, you want to minimize the problem to the extent possible.
The Chef's Choice 3-stage sharpener (Model 110) is a really good unit that doesn't remove more metal than it needs to. There is a 2-stage Chef's Choice unit, but it's more for maintaining an edge; the 3-stage model can bring back a really dull edge. The diamond honing "stones" in a Chef's Choice oscillate back-and-forth instead of grinding in a rotary motion. You don't need to use all 3 sharpening stages on the Chef's Choice every time; you only use the first stage when a knife is really dull. Stages 2 and 3 are the ones to use for maintenance.
My suggestion would be to buy the KitchenAid unit as a neat collectible, but to have a Chef's Choice sharpener for the real work of sharpening your knives. [this post was last edited: 12/6/2012-10:22]
