Daily Driver Recommendations?
johndog
Mar 17, 2013
6
Hello, guys...
I am new to the forum, but probably qualify for the club... After all, my daily CARS are 1932, 1988, and 1997!
We are sick of our newer high-end energy-efficient washer and will be happy to revert to an automatic washer that really CLEANS from another (less regulated) era.
The question: What would members of this forum recommend as a "daily driver"? A Maytag A810 comes to mind, but I really have no clue. I would want something that cleans well, was top of the line in its day, and has reasonable availability of spare parts if needed.
Once I have some idea of what I am looking for, I am sure I can eventually find a "low mileage" example in the Houston area...
Thanks, everyone!
John in Houston
So what is your issue(s) with the newer machine is it just cleaning.
Personally, I would recommend any large capacity belt-drive Kenmore or Whirlpool. You are going to get a lot of different opinions on this, and you have a large choice of machines that would fit your needs.
Maytag is good, but don't forget the Whirlpool DD (direct drive) machines and their Kenmore clones built in the '80s and '90s. Lots of them around, they wash well and are probably the most reliable washers ever made. I've got an '88 Whirly Design 2000 that has been in daily use since new and has never had a repair. Granted I know the drive coupler is on its way out, but that's a simple item to replace. The third washer to consider is the classic GE Filter-Flo and its' cousin the Hotpoint rim-flow. They use a lot of water but wash well and filter superbly.
Probably the best plan is to become somewhat familiar with all three washers and then watch Craigslist for a lightly used matching set; finding individual washers and dryers is much easier than a matching set, especially if you're picky about color and dryer type so if you can be flexible on the brand you'll be more likely to find a good upper-end set.
Welcome to our little slice of appliance heaven!
<a name="start_45533.666570">After all, my daily CARS are 1932...</a>
We are gonna nee to see pics of that '32,  please :D
<a name="start_45533.666570">What would members of this forum recommend as a "daily driver"? A Maytag A810 comes to mind, but I really have no clue. I would want something that cleans well, was top of the line in its day, and has reasonable availability of spare parts if needed. </a>
If you want to stick with Maytag (good choice!), spring for an 806. It's the same machine as an 810, but has a 4 minute pre-wash cycle that works fantastic for REALLY dirt clothes, spins out the dirty water, and goes into the main cycle (I work on both vintage and modern cars as well and use this feature). It also has a 2 minute deep rinse instead of 1.5 minutes used from the the 10 series-on. But most of all, it looks cool and has a lighted console!
Starters
Washers----If your goal is very clean and well rinsed clothes from a reliable older design, and your intention is not to start a large collection, then belt-drive Whirlpool-Kenmore's or Maytag 08 and 10's are easy to rejuvenate, parts are plentiful and affordable, and the machines are tanks.
Dryers----whether gas or electric, the Whirlpool-Kenmore's with the filter in the rear right top of the machine near the console are the best---big drums, long-lasting, simple maintenance, easy parts avaialbility.
Any of the designs mentioned are still plentiful on the used market, search some thru this website to know what to spot, then spend a bit of time daily on your local Craigslist, something will show up. Also, all of these designs came with few options/low budget up to fully ritzy with lots of bells and whistles, but the internal mechanics are the same and dependable.
Thanks! (Keep those cards and letters coming!)
Thanks for the answers so far...
Roscoe, our current machine is an almost-new Kenmore HE front loader... The issues are that each load takes twice as long and clothes must be washed in one-third size loads to get clean. So compared to our memory of 3 washers ago, each clean "load" takes SIX times the time and THREE times the effort. There is no efficiency in that! This Kenmore, by the way, replaced a Maytag washer that had the same problems. We thought we just got a lemon in the Maytag, so we carefully researched Consumer Reports before replacing it with the Kenmore... only to realize that ALL 21st century washers appear to have this "energy efficient" design.
Don't even get me started on low-flow shower heads and corn-diluted gasoline!
Dan, here is a picture of the '32... It is a Cadillac V12 Seven passenger sedan!
Thanks!
well, for starters this would be a set in your area, these are Kenmores, the washer more along the lines of TOL for electro-mechanical...rare but possible of finding a Digital set from the late 80's early 90's would be sweet, they even have fully automatic dispensers and lights...
it also depends if you want from a used dealer with a warranty, or something from a regular person, and may have to do a little cleanup...
http://houston.craigslist.org/app/3684854285.html
I'm Not Sure....
....I can advise you.
Judging from the picture, your idea of a daily driver and my idea of a daily driver may be two different things!
the 1979 Kenmore Electronic.....I have the matching Dryer comming as well.....
wonderful shape, and super bright white, but I rather have the control panel from the direct drive years, more flexible controls, and full flourescent console light...
I also say
Kenmore and whirlpool, I use a 83 Kenmore washer and a 73 Lady Kenmore dryer, at least one to two loads a day, more on weekends for about five years and not one repair!
