I've owned the subject fan since the '70s and it performs well, but since I got some excellent input and advice on my recent Graybar find, I thought I'd ask the experts here about something that has always bothered me with the Vortalex.
Upon starting the fan, it makes a rhythmic chattering/squealing/rattling sound associated with the increasing RPM before quieting down to normal after reaching full speed. I have a feeling that whatever is causing this is also causing the motor to be kind of slow about getting up to speed, as in, maybe 5 seconds or so. The sound is barely noticeable with the blades off, and the motor reaches full speed a lot quicker. The blades are balanced quite well. There's no shaking or quivering from the cage, and just minor vibration in the stand that I think is more about the motor than the blades.
Right now I have the washers configured with a relatively thick rubber one sandwiched between two fiber ones on each side. These washers came from Darryl Hudson, who I found on the AFCA site back in the good old easy access days. This washer configuration is the same on the front and rear portions of the shaft, so there are two pairs of fiber washers surrounding two rubber ones, for a total of eight fiber ones. Free play is minimal, but the fan will run for hours with no overheating or other ill effects. If I remove even one fiber washer, it can develop a slight rattle.
Since the early '30s Graybar is practically silent and attains full speed almost instantly, I'm wondering if the Vortalex should be behaving the same. I found a Vortalex restoration posted on YouTube in three separate installments. That thing was in really bad shape, but without any major cleaning it was silent and quickly got up to speed.
Any idea what's wrong with mine? I've attached a picture of a 16" model that's the same style as my 12".
Thanks for any suggestions,
Ralph
Ralph
