Your Mission, Should You Choose to Accept It....
Daniel - you are, as the British say, for it. Cleaning these is a bit of a hassle!
The good news is that once one is cleaned, good maintenance (meaning cleaning the filter after every load) sees to it that you never have to go through the job again.
The one in my Almond 806 was so nasty it looked like it had
never been cleaned in all its 35 years of service. The buildup was an unholy combination of impacted lint and lime encrustations. It was tough as cement, trust me.
Cleaning it took repeated soaking in Lime-A-Way, fierce scrubbing with a stiff scrub brush, and finally, cleaning of every damned one of those little holes with a toothpick, which is probably what you're going to have to do. It was Not. Fun. But it has never built up again in the three years since.
Here is a before and after photo, which will hopefully show you that there is hope for even the worst filter. And
YES, that is the identical filter in both shots!
