50s Bendix in Melbourne
gizmo
Nov 17, 2001
2,541
Victoria, Australia
When in Melbourne a couple of days ago I stopped at a demolition yard looking at some building related stuff. To my surprise they had an big old appliance labelled "Old Dryer - $180"
I was looking at it when a worker came over and chatted to me about it. I said "you don't have the matching washer do you, I'm not really interested in dryers."
He said no but said "look at this, its pretty cool how the controls are hidden..."
He then lifted up the flap on top (I had't realized it was an openable panel) to show its controls - hot/warm temp selector, load size selector, timer showing wash, rinse 1,2,3, spin... yes, it IS a washer! A Bendix.
It has unmarked white enamel top and top flap, the front and side panels are painted and badly faded/yellowed, the door boot is hardened and deteriorated but I couldn't see any holes, the top seal around the detergent hole is destroyed. The chrome around the porthole is pitted and the whole machine is filthy. The drum looked fine and turned freely without bearing noise, turning easily one way and some resistance as it it is turning a geared mechanism. Despite having warm/hot fill selector, it had only one inlet valve on the back. It is a washer only, not a duomatic. To open the porthole door you lift the flap on top, press a button underneath whilst simultaneously sliding a trigger to one side.
I'd imagine it is late 50's???
It has a plate attached at the front behind the front lower drop down panel, it says "Made in Sydney by James Kirby P/L under license to Philco USA."
A couple of questions for the experts:
-Are porthole seals and detergent hole seals still available, and what is the approx. cost?
-Does this machine reverse tumble or only tumble one way?
-What is the likely load size? The machine is HUGE but the drum seems pretty small.
- Is this likely to be a bolt down or free standing?
I haven't bought it yet, I am continuing spousal negotiations and the price would have to drop substantially.
Thanks
Chris.
GRAB IT!!!
I have a lot of Bendix parts! I may have just what you need as I know that I have the detergent flume and may have a tub boot too. Don't let this beauty get away! Mark
Hi Chris, this is an exciting find for you. Keep pushing the spouse (its too big to sneak in) :)
Door boots are can still be found, Jon just found a bunch of them from a supplier in England. The soap door boot can easily be retrofitted.
One way tumbling, the only way to wash!
Around 10-12lbs.
It should be a suspension system model that is free standing.
It sounds like it could be a mid 1950's model if the controls are hidden behind a door.
Yes Greg, that's it. I don't recall it having any instructions under the lid though. Greg's picture doesn't appear to have a second door release button under the top flap. The Melbourne machine has a small round pushbutton under the flap, you have to push that button down simultaneously with sliding the front lever to open the door. Sorta childproof I guess.
So if it's one way tumble, does that mean the spin is selected by the motor reversing? Or is there a solenoid to engage spin?
Can anyone post a pic or diagram of the insides (the mechanism, an exploded diagram would be perfect.)
Thanks everyone
Chris.
three speed Transmission
I'm wondering how costly your front loaded washers were build! I can't remember any German front load washer with a transmission. Wash and spin action are allways caused by reversing and changing the motor speed. only early semi automatics had a transission, but only to produce a reversing washing action! The problem of reversing the motor, hadn't already solved in the twenties.
One question: doesn't one way tumbleing tangle the clothes way much?
Every german washer that I can remember has a reversing cylinder!
Hell Spee_man
German washers may never have had a transmission, but German frontloaders always had more motors, which was quite costly too. My mother bought a Bosch in 1966 and that one had three motors. One for washing, one for spinning and a third for the pump. Using a transmission changes that ofcourse.
I guess one way tumbling doesn't have to lead to tangling as long as the drum is big enough and the tumble speed is adequate.
Hi Spee Man
One way tumbling was solved by Bendix in 1937. The trick is to have two sets of baffles of different height.
That way they break up the tumble pattern and it prevents balling of the clothes into tangles.
Bendix actually had a patent on this in 1937.
Thor had a reverse tumbling action in the 1920's but I don't know if they ever patented that.
So if you ever get a chance to look closely at a Bendix measure the baffles in the tub.
Cheers
Jet
Thanx for informations!
Hi guys!
I already cant imagine how this drum works! I was searching for a picture of it, but didn't find any! could anybody draw a simple sketch of it?
But after all its very clever to use a single transmission instead of three motors. Why miele doesn't use such a worthy and technical transmission?
bye
thx jon
Guten Tag
Persil is the best detergent to use in H- axis washers!
I'd love to send you one box because it smells excelent! I think you only have the american Version, must smell different! By the way my nick includes the name of the GDR Detergent Spee.
finaly i must tell you that I'm crazy about the idea to build a miniature Version of a real working H- axis washer (about 2or one labs capacity)! (crazy, isn't it?)I'm thinking about it for a whole week now.Therefore I need to know how the Bendix Drum works! I dont want to use a reversal relay or so to keep the constuction as easy as possible!
Did anybody you know do something like that before?
happy first advent.
