fan-of-fans
On top of fans and appliances, I’ve developed a new interest, lamps.
In particular 6 way floor lamps. A six way lamp is actually a lamp having a 3 way socket in the center, surrounded by 3 other standard sockets. The 3 ways socket has its own knob, while the outer sockets are controlled by another switch, allowing one, two or all there to be lit at once, with or without the 3 way bulb.
I just think these lamps are extremely well designed and versatile.
Older versions typically had a glass diffuser bowl over the center socket, which was often a mogul sized socket to accommodate a 300 w 3 way bulb, with the shade sitting on this bowl. Newer models which are still made today use a typical harp mount shade with a medium based socket.
I also have acquired two old versions with a night light in the base!
Does anyone have these types of lamps?
