nickl
I need some guidance with my "family-heirloom" Maytag A107. It has begun banging on spin cycles. I searched this terrific forum well, but I am stuck on diagnosis and next-steps.
This washer has never been a quiet spinner, but it never hard-banged until recently. Our home-from-college son started hitting it with small loads recently (ugh). It is now starting to bang on larger loads unless the clothes are distributed with the utmost care.
This washer has never needed anything but belts for me or its original owner ... pretty amazing. I have turned a wrench or two over the years, and I'm willing to go long-and-deep if this one can be saved. Its SN ends in UU, so I think that makes it a '74.
This is what I know so far ...
The washer is level, it is on solid flooring, and it does not walk. Its springs feel very solid, and the tub pivots on its pads without any roughness. There is definitely no metal-to-metal contact there.
I'm not sure how much resistance felt-pad washers should have when pivoting. My washer experience is limited to a Performa, and they have very slippery nylon snubbers.
The washer has a chronic lack of balance when spun up, and it does it with no load at all.
There IS some grease underneath when it is tipped back. It appears to have been leaking for some time. I understand that would be the lip seal leaking, and that some leakage isn't necessarily fatal. (pics attached)
There wasn't any grease on the belts themselves, but they were old so I replaced them ... no effect.
I am willing to go after the lip seal (if they can still be had). I would even get into the trans if that is not totally insane. First things first though ...
Is loss of trans grease enough to make these old washers unbalanced or is something else going on ?
Would putting a dry-lubricant on the felt 'damper pads' serve any purpose in diagnosing this ?
Is there anything else I can do toward learning what my options are for this A107 ?
I appreciate anything you can lend to this party. Thanks in advance all.
