I have this He3 dryer that worked beautifully until it started acting up a couple months ago. The cycle would end prematurely and the clothes wouldn't be completely dry. I'd restart the cycle and they' would be dry when it stopped the 2nd time. Someone suggested the moisture sensor bar inside was coated / gunked up because I use dryer sheets. I used an alcohol wipe pad to clean it thoroughly, but there was no change.
Recently the cycle ended and the items were still really wet (as opposed to partially dry). Today when doing laundry I removed the lower access panel to watch what happened. I started the dryer, the igniter started to glow, the gas valve clicked and the burner lit. The problem is the flame went out after 1 minute! I let the dryer run 5 minutes thinking the flame would cycle back on again, but it didn't.
I then thought it would lite again if I restarted the dryer. So I turned it off completely, opened and closed the door, then restarted it, but unfortunately, no change.
Do any of you have any ideas?
Thanks much in advance,
Kevin
Kevin
