cardinal24
On Medium setting: Dryer get scalding hot in perhaps 2 minutes
On No Heat setting: Drying does not get hot.
Where is the heat? The heat is at the top-back, under the panel (knobs, buttons).
Removing the top reveals some nearly-charred area and a thermostat.
Please see the photo which show the hot area and the "nearly-charred" area below and the thermostat, etc.
Thank you in advance.
I also posted 67777 and 68000. Below is a link to 67777.
www.automaticwasher.org
Dryer overheats - Old GE
How can I describe this? ... Dryer overheats ... Dryer spins but gets SO hot, you can't touch the sides and top. Model # - DDE_7109_VM_LAD (underscores inserted for readability) Attached are 3 photos. Most importantly ... THANK YOU. You guys/gals helped us fix our ancient GE washer. She...
