washmania
Hello everyone!
Here's my Dyson CR01. Made around 2002. I have owned this for around 10 years. When I first bought this machine it had a couple of problems such as a leaking sump seal, leaking tub seal, worn shock absorbers, and also a faulty powerboard (which was actually caused by a loose screw making its way onto it and shorting it out). It had not been properly looked after.
Since overcoming those problems, this machine has been totally rock solid and it has probably done well over 5000 washes. Contarotation is perfect. I replaced the motors last year and the brushes still had around 50% left in them. I run Bosch descaler through it every 3 months on a 60 degrees cycle and the inside is as good as new. The display is fading a little bit but I can live with that.
I am probably a bit biased but I think I probably have one of the best of the surviving contrarotators
Hope you like the pictures.
[this post was last edited: 9/30/2023-15:24]
