A circa 1985 GE Laundry Pair TV commercial.......
appliguy
Jan 1, 2005
1,351
Oakton Va.
FROM VENEZUELA!!!!!!! I did not realize that they sold Filter Flo's and the matching dryers in South America and from what they show in the commercial it is the same machines that were offered here in the USA with the only difference being the Spanish(?) writing on the console...anyhow I thought you all might get a kick out of this....PAT COFFEY
Did you noticed the music in the back ground, it's more
It sounds a little like it...maybe....but it is not the actual tune...I went back and listened to a few times and I do not hear that music to be to similar to the Sears jingle song.....PAT COFFEY
Venezuela built GE FF Washers
We have run into several 24" wide full sized FF GE washers that were made in and imported from Venezuela here in the DC area. Its an neat machine as they turned the inside of the washer around 180 degrees so the pump and motor are in the front left side and added a removable front panel for service [ GE commercial washers did the same thing here ] I always thought that GE should have done this on all there FF machines and gotten rid of that CHEAP Cardboard back panel. The 24" GEs were neat washers as the recirculating water for the lint filter entered at the 7 O'clock position.
