Servicing a DE606HOH dryer
Hi Dave, you can oil those Emerson motors by drilling a hole in each end and putting in some light electric motor oil.
If the motor in the dryer smoked up the whole house, it’s the start winding not just the switch. If you look carefully into the motor, you’ll see that the inner start windings are probably quite toasty looking.
Yes, it looks like the replacement motor also has an aluminum pulley. It must be pretty low Use to be in that good of shape. It’ll work fine for many years. No reason to worry about replacing it with a steel pulley unless you’re gonna be putting a lot of hours on this dryer.
On the blower, the bushing is supposed to stay in the plastic housing, if the bushings aren’t too worn, I suppose you could try gluing the rubber mounted bushing back in place with some really good RTV type sealant or glue, generally when we had a bushing do this we just replaced the blower, but they’re not that readily available anymore so you might have to get creative if you don’t have a good spare.
John L
