Thanks Ben!
I've decided to do the following:
A) Switch to a 50 cycle motor pulley and set of 50 cycle belts if available. If not, I'll
put on new belts.
B) Install the Load Sensor agitator.
C) Switch to the WP inlet valve.
D) Rebuild the motor glide.
The transmission if working properly, I will leave be for now. And this is assuming the washer is working correctly at it's maiden wash.
As for the dryer, I have not made the 220 volt installation yet, so I have no idea if ultimately it will be true 220 service or 208V.
[this post was last edited: 3/13/2018-15:17]
put on new belts.
