A productive afternoon ........
The Hoover.....
Ive also ordered a new sump hose- its just starting to perish. Id say the leak was the door gasket tho.
mus
Sea
Great machines - if I ever get a FL it will be an old Hoover. Years ago we had a Hoover Electron 800 and although it was a bit noisy, it was a great machine. Would love to get hold of one of those.
Thanks for the pics
Hi Seamus
This machine looks great, have you tried it on yet? So was the leak the rubber door?
This looks like it has the classic Hoover drum which I love. I'm still searching for one not too far from me.
Take care
Rob
Seamus
Hi seamus
Is it possible you could do a drum shot of the servis, I just wanted to know if the drum was smooth inside, I had the servis dryer to match the machine you have but it has sadly long gone, was only a small drum and it took forever to dry anything... Many thanx in advance
robbie
Questions........
Rob
There is no evidence of scale etc underneath so am assuming the tub shell gasket(as Hoover used to call it lol) was the problem- however its not been water tested yet as the sump hose is starting to crack/perish
(although it dosent appear to have got to the hole stage) and will be replaced before its tested properly.
Robbie
The Servis has a normal preforated drum. Its a pretty late model and from after the Spincare drum range. Darren (newwave1) has an earlier model with the solid/Spincare drum.
Seamus
