A project completed - 1950 Westinghouse Wash-Well automatic dishwasher
turquoisedude
Aug 8, 2007
10,589
I've had this dishwasher for quite some time... I acquired it from a fellow automaticwasher.org member in Arkansas, had it shipped to another fellow automaticwasher.org member in Ohio, then finally brought back to the house in Ogden, QC back in 2022. I began the restoration in 2023 and there was PLENTY to do...
Just about all the wiring in the machine was nice and crispy, the timer drive motor was seized up, and so was the drain pump. But the biggest challenge was the drain boot between the dishwasher tub and the pump.
    18.8 KB
    1.3 MB
    1.6 MB
    1.5 MB
    1.6 MB
    1.7 MB
The timer was an easy fix - swapped the old motor out and new one in. The pump was salvageable! It needed a good cleaning out and lubrication but it came back to life. The drain boot replacement was a bit more of a challenge... I managed to substitute some standard plumbing fittings but the design of this machine was such that a solenoid was used to pull the pump away from a drive wheel in the main motor when it was not draining. My new 'boot' was less flexible than the original one and soon resulted in a failure... The original solenoid burnt from the strain and a new heavier duty one did not do much better...
    2.2 MB
So the machine sat for another year before I really started working on it again. I had time to figure out an alternative method of driving the drain pump. I added a sewing machine motor, powered by a DPDT ("reversing") relay so the new motor would run when current flow to the original solenoid was cut. Convoluted, ugly, and noisy, but it works!
    1 MB
    1.2 MB
I decided to repaint the front panel white again. Pink was not offered in 1950 and I'm a bit of a purist... And a bit OCD... LOL. It was time for a test of the machine at last!
    874 KB
    1.1 MB
    1.2 MB
    1.1 MB
    1.2 MB
    851.1 KB
I hit a couple of minor issues... a leak in the water supply to the tub due to a loose connection and the control knob no longer was advancing the timer actuating arm. I had somehow lost a bolt holding the ribbon-like control strap that connects the knob to the timer arm... Got that fixed today and Woo-Hoo - I call this project "DONE"!
    1 MB
    1,008.5 KB
I had that dishwasher in my kitchen for about 3 years Paul and really liked it. It was one of the better cleaning impeller dishwashers, this and the Hotpoint impeller cleaned the best. It was also very quiet as I remember.
Great job Paul and very nice dishwasher! What a project you started out with and to end with such a well done finished project - I admire your perseverance! I'm with you on the white vs pink - it looks perfect. Thanks so much for sharing.
A relative of mine in Miami had one of these. It did a really good job for an impeller model. When it let the steam out it had a very distinctive odor, kind of like a vintage Bendix Combo. of the era.
You did a good job, as usual. I hope you enjoy using it!
Fun read. Silk purse from a pig's ear or how ever it goes. Love the load pics, the circular pattern and the colors, so pretty. Had the same luck using plumbing parts to get the Turquoise Spintube up and running, Fun that you've got a sewing machine motor to do the pumping--
"Convoluted, noisy.and ugly" All the better! Wonderful work, Paul.
