A serious try at Bright White LED in a Bed/Rec/Sleeping Room
daveamkrayoguy
Silver Member
Dec 8, 2010
5,724
Oak Park, MI
Two 60w in my table lamp, dimmable but can't stop the initial flickering, which isn't that distracting...
Hard to disassemble my overhead lamp which I keep a 100w and want to change the bulb in it as little as possible, though it did need a bit of dusting...
There is a living room at the house across the street from us of which employees a lamp there giving off a white light there as the lighting in all the rooms at a Motel 6 Budget-type Inn, particularly where us guests stay in, all in interest of keeping rates as low as back in the days of staying. for only $6...
Of which I roomed at last year, a hotel actually serving only coffee the next day--no continental breakfast even as any sort...
So here's it here, as many pics I can post per post:
-- Dave
And did my best to,photograph the entire room, including a yellow incandescent which like the yellow bug light incandescent which serves as a mood/night light could not find an LED equivalent for, and I tried to replace that bug light even first:
(maybe a couple duplicates or so, only got 18 in previous shot)
-- Dave
Led light bulbs
I have a pendant set in the dining room that has 5 candle bulbs in and typically the 2 near the top had blown as they were all ordinary bulbs and as its particularly difficult to get at the bulbs I decided they all needed to become LED so they would use less power and also need replacing less often, However I encountered a problem as in you could not change the bulb without dismantling the entire light shade so I needed a way to change the bulbs and not have to get finger prints on the glass I will put pics of said light and my invention to change the bulbs...It is just a cardboard tube from wrapping paper I think and around the end I put some double sided adhesive foam and you simply place the tube over the bulb and screw it in or out.
