First, I did pull unit away from wall and look for obvious leaks, found none.
The washer fills the tub no leaks then once agitation starts it begins leaking and stops progress. The dashboard light stays on telling me it is still "on" but it will not progress unless selector is pushed in and advanced then pulled back out. Any ideas on what would cause both a leak and a work stoppage?
Thanks
EE
Thanks
EE
