Vintagelectric
- Joined
- Mar 20, 2016
- Messages
- 5
Hi
When I say add oil I mean how much to add with refrigerant when refilling after evacuating and vacuuming out the system. I have a 52 ge combo and a mid 40s early 50s wards (frigidaire) single door that both need refrigerant. The compressors on both run very quiet, I let both run for about 2 hours since they've been unplugged for years. The frigidaire wards has the famous meter miser compressor which I heard the refrigerant can settle and need to run for quite some time before it cools but I figure after 2 hours it would do something. I bought bullet pierce valves a vacuum pump, r 12 gauges and 3 14 oz cans of r12 and 2 12 oz cans with oil. I also thought of getting red angel AC stop leak and an injector they claim it's a nontraditional stop leak that acts as a lubricant until it finds a leak.My question is how much oil does a refrigerator generally use? The ge is a split system uses 10oz r12 for the primary system but the amount for the secondary is rubbed off the tag. GE Model ah-83-aa16. And the frigidaire uses I believe 26 oz r 12. If anybody has any info on how much refrigerant the secondary system uses on the ge and how much oil these take I would greatly appreciate any info. The wards frigidaire is a O5DOS970A. I just thought of getting the stop leak since they say the only way refrigerant gets out of a sealed system is from a leak. With the cost of r 12 and the company claiming this stop leak is basically used as a preventative I thought it would be worth a try.
Mike
Mike
