So, it overrides your manual water level selection?
Hi Louis,
My rule of thumb with water levels is to loosely load dry clothes into washer and select water level to come up to the height of the load. Looking at the dry load in your machine I would have thought that water should only have come up to the fourth or, perhaps, third hole from the top of the basket down.
Once dry clothes become saturated they compact and create enough space to allow for turn-over. Of course it depends on the types of materials that are being washed, but your load looks like a regular mix without heavy or unyielding materials that get water-logged and require more room to move. Your amount of laundry looks like a half-load in my washer.
I've used a Haier top loader of similar design at a client's home. It had both auomatic and manual water level selection. Being the control freak that I am, I've used the manual option and it did not automatically top up the water level.
Overriding your manual selection may be a design quirk particular to LG or the electronics that control this function aren't working properly anymore.
Your machine has travelled half way around the world and was probably bumped and shaken. That's the thing about complicated high tech stuff, when it works right it's magic, but it's sensitive and prone to go bung at the drop of a hat.
Is there a program rest-function on your machine?
Anyway, don't let this spoil your fun. There is nothing more soothing than watching laundry swirl through hot sudsy water. ;0)
Cheers
Olav
Hi Louis,
Cheers
Olav
