This is probably the first of a series of questions. Perhaps you experts can guide me!
In this case we have a 1958 Admiral range that resides in my late MIL’s basement. I learned to can on this range, but for the last twenty years it has been unplugged. This puppy is pretty rough after a long life on a farm.
We plan on using it for canning again, so rather than scrap the thing I am going to try to save it.
Try…
First problem. The oven hinges on both the main oven and the “thrift oven” are malfunctioning pretty badly. They are stiff and the doors don’t close evenly. It appears that there may be a spring broken on both sides. Not sure.
Q: How do you get to the hinges to repair them? I kinda doubt that removal of the screws would allow removal of the hinges from the front. Am I wrong about that?
Q: Do you have to use a special grease to lubricate them? I don’t know if the heat of the oven causes some greases to run, separate or smoke.
I found some glaring faults upon quick examination. There is evidence of old wiring repairs and a connecting lug completely came off a Calrod burner. The Calrod lug and its wiring landed on the metal frame. This is why one checks these units before applying power…. I’ll forward pix of the burner later. I do not know if Admiral burners are universal or not.
All comments welcome.
Try…
