OTR Micro-Wave-Ovens
In a one word answer, DON'T do it, take it from someone that repairs HUNDREDS of these a year.
Installing a MWO over a range is a terrible place for a plastic electronic product, imagine installing you computer over a kitchen range.
OTR-MWOs are a major fire hazzard, they get bad grease buildups inside where you can't clean and when you have a range top fire the whole kitchen and house goes up in flames when the plastic starts burning.
A few other points and corrections, there is nothing wrong with venting an OTR_MWO through the space above cabinets, as long as it is done in steel ducting.
The most common repair we do on MWOs is replacing bad Magnetrons, the Mag tube still has a filament in it and it has a diffident life, and to make matter worst they are pushing 1100 watts out of the same size mag tube that used to deliver 600-800 watts, so the tubes don't last long.
You are far better off installing a MWO on a shelf or getting a GE space-saver and hanging it under a cabinet away from the range top.
And always get a good range hood and vent it outside especially if you have a gas range which produces a lot of carbon monoxide.
John L.
John L.
