Another Coin-Op Question - CEM2940TQ1
DADoES
May 21, 2001
15,813
TX, U.S. of A.
Complaint that it won't take coins (presumably jammed mechanism).  No problem when I tested, coins dropped right through (slide return springs are broken, doesn't affect the drop).
The start button is bad, continuity across CO/NO terminals without pressing.  Dryer starts immediately upon 1) engaging cycle with coins, 2) closing door after opening, 3) disconnecting/reconnecting power cord.
I disconnected the NO wire to confirm ... doesn't start until touching the NO wire to the CO wire/terminal.
Now, it never shuts off.  Been running for probably 4+ hrs.  The timing cam (45-min cam) rotates so presumably the timer works.  I didn't notice if it turned prior to disconnecting the NO wire but it does for sure with the wire disconnected.
Is there a way to manually turn the timer to Off?  How long is the full possible cycle duration?
