Another one in my backyard
turquoisedude
Aug 8, 2007
10,589
This one is so close that I could walk back to the condo in Montreal with it!
I am sorely tempted by this Inglis Royal dishwasher... I am going to guess early to mid-70s judging by the dial and the door latch. The notion of two speeds is intriguing. I remember seeing that featured on Inglis (and a few of the last Belangers, which were made by Inglis anyway). Did the US Whirlpool models have something similar??
Yes, we had one just like this Whirlpool Supreme 80 with removable cutting board (1/2) of the top of the machine. That door lock was a pain it always seem to become loose and we had to keep tightening the set screw under it.
this is a great dishwasher i know because when my godmother may she rest in piece moved in her 73 home that she bought in three rivers that was the exact model dishwasher she add but built in so its a great machine and i would love to see a vide of this dishwasher in action if its possible thank you
As I recall, two speeds in this case does not refer to two motor speeds.  Reduced spray pressure was garnered by some other method, such as a valve that opened to allow air into the pump or by a 1/2 fill.
WP 2 SPEED DW
This one used a lower fill when running on gentle speed which caused the circulating water to aerate and reduce the water pressure, earlier WPs used a solenoid valve to let air into the pump to do the same thing. GE DWs also had an air induction on some late 1960s machines.
