passatdoc
My father has a roughly ten year old basic KA DW. He refrained from using it because the controls were different than on the prior GE and, being single, he preferred to hand wash. The KA was used now and then, usually only when his kids were visiting and there would be more cooking and dishes to clean.
Was there over Thanksgiving and I checked the rinse agent dispenser. This has an optical indicator: you open the door flat, if there is sufficient liquid it appears dark; if not enough, the indicator will appear light (if inbetween, the center of the indicator is dark and the perimeter is light).
The indicator showed it was time to add rinse agent, but when I added liquid to the filler port, it just sat there and drained into the reservoir very slowly. Now and then you could see a bubble of air rise up, indicative that a few drops had slithered down into the dispenser, but it gave me the impression there is a clog in the system. Admittedly, the DW was literally used only 3-4 times a year for maybe five years, until we prevailed upon him to start using it more often, since machines like this do better if used semi-regularly than twice a year.
My concern is that the rinse agent may have dried up or become very congealed, from months of non-use, and now it won't fill properly. He gets decent results using Finish Powerball tabs, which allegedly have rinse agent in them, but I don't see how something released into the tub during the main wash can survive/remain in the tub through the final rinse. I use the same tabs at home, but keep my rinse agent dispenser filled and do not assume that the Powerball is doing its job (maybe it is, maybe not, but I can no longer find non-Powerball tabs for a comparison wash....they used to sell Electrasol/Finish sans Powerball, but not recently).
Anyone have any ideas for cleaning out the dispenser? THis seems like a very rare issue that only affects stubborn parents who refuse to learn the controls of a new DW!! Even if I can get the rinse agent into the dispenser with patience (like a slow running sink drain), I'm not sure it's really being dispensed properly.
