AquaSmart - Bulky / Blanket Cycle
DADoES
May 21, 2001
15,817
TX, U.S. of A.
Includes Eco Active suds cake.
The impeller doesn't stop rotating at 11:06 during fill, the load has floated up and lost contact with it.
A 30-min soak period is hard-coded into the cycle (pressing the Back button optionally aborts the soak after it begins).  Soak periods include periodic recirculation showers and agitation mix-ups.
I have it set for 15 end-of-cycle beeps.  F&P washers beep the EOC signal for some reason at the start of soak periods.
post was last edited: 2/22/2020-15:58]
It's plainly obvious that a lot of time and thought went into the design of the cycles on that machine.  Loaded properly (as you do) it seems to do a great job.
