I have a few of those latex backed rugs around the house and was doing some heavy cleaning and tossed the semi large rug from my back entry into the Duet, had a thought or two about if it would be ok, but decided it was gentler than my TL. I've had rug self destruct in my TL and it's a mess to clean out, but easily doable. The FL was another story.
Kept getting Suds errors, machine would not drain and I had to pull the dreaded pump filter out -- with a tub of water! Tried various pans and such, no go. Decided on just sucking up the water with my floor scrubber. It's a finished basement but the floor has survive many a flood over the years, but what a mess. Ton of particles caught in the boot area, machine blipped out again a second time with a plugged filter. Running a cleaning cycle now, will check the filter one more time before replacing the front panel.
After all these years you would think manufacturers could come up with a better backing, at least one that comes off in strips or sheets rather than tiny particles.
